| glass layup Hi, I've just bought a mould for a 10' pram dinghy. I am experienced in wooden dinghy construction and am looking to try out a glass number. Can anyone advise on the correct weights of cloth to use and suggest how many layers etc.?? I envisage around 6 hp. outboard and a max load of around 450lbs gross. I will be laying up with polyester resin. Cheers all. conyermud |
| Glass lay up ? Hi have you had any reply's as to the glass to use ? |
| layup hi, no, had no replies as yet, thanks for your interest. Gordon Inwood |
Rx |
| layup... Hi, thanks so much for the offer of help. The mould is around 48'' wide at the lowest chine, it is a very shallow vee, noticeably rockered along its length. Do you need anything else?? conyermud |
| A simple lay up for a dinghy 1 -GEL COAT ALL OVER 2 COATS IF BRUSHING 2 -1 450 GRAM CSM TO COVER GEL AS THE FIRST SKIN 3 -1 450 GRAM CSM + 760 GRAM WOVEN CLOTH OR A FABRIC OF THE SAME WEIGHT ALL OVER . OVERLAPS ALONG THE CHINE AND ALONG THE LENGHT OF THE KEEL . DO THE BOTTOM FIRST AND LAP THE TOP SIDES AND TRANSON INTO THE BOTTOM ALL OVER LAPS SHOULD BE 50MM OR MORE 4 -A SECOND LAYER FOR THE BOTTOM ONLY -1 CSM 450 + ANOTHER WOVEN MATT TO FINISH WOVEN MAT HAS A 150GRAM SCM ON ONE SIDE SO MAKE THE CSM FACE UP WHEN YOU LAY THE LAST ONE . THE TRANSOM NEEDS PLY TO HOLD THE OUTBOARD . WILL GET BACK TO YOU WITH THAT ONE |
| layup.. You star.. thanks so much for the help. I can start working out areas and getting a buying list together now!! Conyermud |
Stitched fabrics are inclined to shear between the glass layers under hard impacts The transom need to be strong with a finished thickness of around 40mm +. It needs to be robust enough for a 10 hp outboard at least . Build it strong so it will last the distance . Never underbuild a small boat |
| Are there catamarans with glass bottom salon? | kode | Boat Design | 8 | 11-07-2005 08:36 AM |
| Canadian Canoe layup schedule | cadmec | Fiberglass and Composite Boat Building | 7 | 11-05-2005 11:38 AM |
| carbon glass balsa core | rturbett | Fiberglass and Composite Boat Building | 8 | 08-31-2005 12:18 PM |
| epoxy and glass inside and outside? and more | Nordson1960 | Wooden Boat Building and Restoration | 6 | 05-22-2005 09:26 PM |
| UK - Fibre Glass Workers Required | MnM Int. | Services & Employment | 1 | 07-07-2004 10:42 AM |
