Old 12-06-2007, 02:22 AM
elegant bass elegant bass is offline
glass lay up information for boat speed boat
hi need some info on how to calculate glass thickness on speed boat do have the mould to build the boat but don't have the glass lay up information if any one would shed some light on this project of mine i`ll appreciate your help.
raffi
17ft x 6ft beam
boat is for skiing with family and friends if it ends up heavier hull should i use chop mat or other type of material please specify thanks.
planing on putting two stringer 12mm thick each glass all over + center keel stringer false floor 12mm ply transom3x12mm ply glassed in between each ply. planning on having the hull 8mm thick 12mm transom 6mm sides and top deck is this OK or to light. can i use one type of chop mat or different weight. thanks for all the input.
raffi
Old 12-16-2007, 03:53 PM
ratrace2's Avatar
ratrace2 ratrace2 is offline
Rep: 84 Posts: 542
I have been looking at the same question, since I have a couple of mold in mind and was thinking about the layup schedule myself. I have read that you need anywhere from 1.5 inches to 5 inches of fiberglass on a 30' ft boat. In the 1990's the routine was just to use mat and roving with a vacuum infusion system. For example, take some 20 oz. roving and a layer of 1oz. mat and apply that over about a .125 1/8 inch of gel-coat. So, you would spray your pva (mold release) into the hull mold, right. Now, spray a good coat of gel-coat (about three coats) and let it dry for a couple of hours. Now, for the fiberglass: (You can get mat and roving stiched together, anyway), Lay down a layer of mat, then lay down a layer of roving. Keep laying down mat/roving, mat/roving, mat/roving until your hull thinkness is about a 1.5 inches.
Old 12-16-2007, 03:54 PM
ratrace2's Avatar
Rep: 84 Posts: 542
Let me know if you find at anymore than this.
Old 12-16-2007, 07:39 PM
ratrace2's Avatar
Rep: 84 Posts: 542
Glass layup schedule
I hear it's about 12mm or (.047 inches) for 40 ft..........but that is just the beginning...............read carefully
Old 01-20-2008, 12:52 AM
ct marine nz ct marine nz is offline
Rep: 10 Posts: 28
Gelcoat
225csm
450csm
300 gm kevlar
600 edbm - eglass double bias
1mm coremat from chines down
600 edbm
225gm csm -if you want to have it looking tidy
we use it and never have had a problem whats more important is the secondary bonding of stringers
Information regarding recycling of wastes generated from small fiber glass boatmaking sivaramakrishna Services & Employment 5 02-03-2009 04:18 PM
Looking for information about project boat. BMH Sailboats 15 10-06-2006 11:11 AM
Glassmaster Boat Information Doughboy Boat Design 1 08-22-2005 04:44 PM
Information Reqested Regarding Fiber Glass Boat Manufacturing sivaramakrishna Boatbuilding 9 08-25-2004 08:16 AM
Want to make a glass Raceboat...But... what lay up????? RT's Fiberglass and Composite Boat Building 2 06-17-2004 10:10 AM
