Old 02-25-2009, 07:53 AM
billjoat billjoat is offline
Rep: 10 Posts: 3
'glass covering
I'm currently building a Spira 24' chesapeake stretched to 26'. Ply on frame construction. I've 12oz biaxed the seams and am now proceding to cover the hull. Is 6oz cloth a suitable glass along with epoxy for the covering or do I really need to step up to something like the 12 oz biax like I used for the seams? I'm thinking a 6oz cloth layer with an extra layer of epoxy will smooth it out rather nicely for waterproofing and I do not need the extra strength of the biax since its framed the way it is.
Thanks
Old 02-25-2009, 11:36 AM
Rep: 3125 Posts: 9,399
Biax is a lot harder to smooth out the regular cloth, use the 6 ounce. 6 ounce is fairly light weight stuff, but will offer abrasion protection and water proofness. I generally use 8 ounce and a minimum hull sheathing, unless it's a bright finish, where I use 4 ounce.
A 12 ounce sheath is pretty thick and heavy. I wouldn't bother unless you expect fairly rough usage.
A single layer of biax on the outside seams is fine, but do yourself a favor and use a healthy fillet (50% silica, 50% milled fibers is a good mixture) on the inside and a couple of staggered layers of biax on these seams. The inside seams will be taking the brunt of the loading, so make them stiff.
covering a new floor rabbithutch Boat Design 4 09-14-2008 10:18 AM
covering a new floor rabbithutch Powerboats 0 09-13-2008 08:37 PM
covering ply lorri Wooden Boat Building and Restoration 7 09-22-2007 11:21 PM
painting hull - covering Print Through superfly Fiberglass and Composite Boat Building 4 06-16-2006 06:29 AM
Covering for Drafting Table Robert Miller Education 4 02-05-2004 04:02 PM
