| getting that mould perfect I have manufactured a kayak mould and found getting those last sanding swirl marks out very hard and frustrating. Does any one have any tricks that might like to share in getting that mould perfect? Thanks
__________________ nadgeekayaks.com.au |
| You have to buff them out with a product made for buffing out "those last sanding swirl marks" in fiberglass molds. I haven't been involved with molds for awhile and don't know the latest bestest stuff, but someone will come along who does. It is not hard to do and within an hour your mold will be perfectly shiny. |
| I've done my share of fiber glass repair and what I used to fill swirl marks is called glazing compound its almost like wood filler I would use a heavy squeegee and just press it into the area and squeegee it over if done right no sanding is needed works like a charm and Im sure it would fill those swirls no problem
__________________ I am skeptical of the deniers diatribe |
| Awesome thanks The mould has come up perfectly sanding down to 2000 wet and dry and then cut polish followed by a finish polish and since you know it so personally after making it, in the right light or shade I can see these little swirls here and there and want a 100% job Thanks
| ya well if you dont get those out of the mold you will probably have them show up in your finish product so cool stuff is most easily obtained from the folks who make Bondo for cars they use it to fill little bubbles in the bondo
| Glazing compound is not for tooling surfaces, it won't hold up. |
A white or light colored product shows up flaws the least. |
| Have you tried buffing with toothpaste?
| The way we do molds. 1. Build plug and smooth - apply tow coats of silicon free ram wax. Then cover over with PVA mold release. 2. Laminate the mold in/over plug, reinforce, cure and the remove from plug. Wash PVA of mold. 3. Now the fun starts. The complete mold get sanded down with wet/dry sandpaper in the following sequence; #400, #800, #1200, #2000 grit paper. When at the #2000 stage, the mold should be glass smooth with all imperfections such as "orange peel" marks scratches etc that may be on the mold removed. 4. Now start with silicon free release ram wax. I usually apply about 7 coats with each coat polished to a shine. After seven coats the mold will be mirror like and the moldings popping out later will not stick and have a high gloss and smooth. Usually, after a molding is popped from the mold, we give the mold a light single layer of polish before starting the next molding. From experience I found the best way to apply the ram wax is to wet the applicator cloth before applying the wax. This will make buffing easier and not get sticky. Let it dry, buff and repeat as many times necessary. BTW, at my shop we only polish and buff molds by hand. The polisher is only used on moldings that may need a bit of shine. Hope this helps.
| Thanks, Wynand. ![]()
| I've read a number of times where people do the majority of the finish work on the mold instead of the plug. It's never made sense to me because it is so much easier to work on the positive convex plug (outside of a ball) than the negative concave mold (inside of a ball). Working on the plug allows one to use long sanding boards and powered sanders etc. Working on the mold usually means small sanders or actual hand sanding which introduces/enlarges the irregularities which give unfair, rippled surfaces. Although a mold may be perfectly smooth and shiny, if it doesn't have a fairness over the whole surface that leaves solid straight edged reflections, it lacks the ability to produce a quality product as far as appearance goes. There is also a tendency for whoever builds something to see problems that no one else ever does. As far as getting rid of them, I guess it depends on from what stage of finishing the swirls were left. I had a brand new buffing pad leave a series of swirls all over a new mold once because there was a tiny lump of excess glue in the lambswool (from the glue that glued the lambswool to the pad). You might check that. |
By making a living as a professional GRP boat builder / fiberglass product manufacturer, I learned the hard way what works best for me. Exactly why all my molds only get polished by hand...being there, got a T shirt and a badge ![]()
| Awesome replies --I'll take heed of some of this advice and some of the links were helpful as well
| One of the best products I have found to remove swirl marks is 3M polyurethane polish, and use a waffle sponge pad.....it is designed to remove swirl marks from two pack after repairs, very , very fine polish.
| The Perfect Sharpie | Brasstom | Boat Design | 15 | 03-23-2011 12:04 PM |
| Perfect Houseboat Couch | Plastech | Marketplace | 0 | 07-16-2009 04:13 PM |
| Towards " THE PERFECT BOAT" vs " MY PERFECT BOAT"..(Part 2): SUCCESS !!! | zmfmd | Open Discussion: All Things Boats & Boating | 1 | 01-18-2009 02:16 PM |
| Perfect | Sean Herron | Boat Design | 5 | 12-14-2008 04:35 PM |
| The Perfect Sailboat... | Sean Herron | Boat Design | 16 | 09-21-2005 01:15 AM |
