Old 07-06-2006, 12:23 PM
Searay31 Searay31 is offline
Rep: 10 Posts: 12
General Newb questions
Im getting a 31 ft 1980 Searay SRV Sedan bridge.
All the rear deck flooring is off.
The stringers look good and solid. But i want to work up,
What are a few things (while the inside/outside deck is off) too do, too improve the stringers, Coating ect ect. I figure if im already there
ill go ahead and make everything 100%. Suggestions on what to use
to recoat that whole area below decks.
Next i want to replace all the deck support wood.(only the back deck. What is the best wood to use for this? How should i coat it for a long life?
Last i want to install the deck wood it self. I heard of a product that has ply with foam center? Its called something like coose board or simular? whats your thoughts on using this for the back deck?
Thanks and sorry for the lack of terms, im new to all this.
Old 07-06-2006, 07:40 PM
buckknekkid's Avatar
buckknekkid buckknekkid is offline
Rep: 37 Posts: 345
search the forum
we have been gabbing away about this subject. Are you getting the one that was the freebie?
Can anyone spare any gas today for a hamburger on Friday ???
Old 07-06-2006, 11:40 PM
Rep: 10 Posts: 12
yep i am, and i have been reading for days, just looking for suggestions
on above questions thxs
Old 07-07-2006, 08:10 AM
Rep: 37 Posts: 345
heres where you start
toss everything out, including the crapper. then clean and grind away all of the dirt. then the fun begins. photograph and label every piece as a template for later.
Old 07-07-2006, 09:13 AM
The Kid The Kid is offline
Rep: 10 Posts: 12
My recommendation is to cover all new wood below decks with fiberglass resin. This would eliminate moisture entering wood later in life.
Support wood, if exposed to moisture, either above or below decks should be coated. The above method works, or paint.
I never heard of the decking wood you mentioned. If you are going to leave the wood showing, I would use teak. If not, use marine plywood and cover with fiberglass resin.
Old 07-08-2006, 06:32 AM
Rep: 37 Posts: 345
exactly, Epoxy is your new middle name.
Old 07-08-2006, 03:25 PM
Rep: 10 Posts: 12
Thanks for the help
Should i go ahead and recoat everything from front to back incl stringers ect?
Even if coated? I have no back deck so its easy to get at now.
Any suggestions on the Good epoxy would be great, also with a light sand
can i recoat the epoxy thats already there? Thanks again
My crapper is hooked up and looks good, im keeping it!
Old 07-09-2006, 08:34 AM
Rep: 37 Posts: 345
Ok then just buy a new seat, the ladies will appreciate it. Everything looks better when its coated, painted and shiney
Some questions. fcfc Option One 10 11-05-2006 05:39 PM
questions Redsky Wooden Boat Building and Restoration 13 07-07-2006 02:00 PM
Rhino Questions CET Software 23 03-19-2006 04:11 AM
The General Public... Sean Herron Open Discussion: All Things Boats & Boating 0 03-31-2005 09:27 PM
New and full of questions Dutch Boy Boatbuilding 4 05-18-2004 04:51 PM
