Old 01-22-2010, 03:55 PM
dinoa's Avatar
dinoa dinoa is online now
Rep: 51 Posts: 57
gelcoat alternative
I read in the Sailing Anarchy Forum that some builders were applying paints as a first coat in the laminating process instead of gel coat. PPG 700 and 1000 were mentioned which are industrial epoxy/siloxane hybrid paints and applied directly on the mold release surface in 4 coats before laminating.
Has anyone had experience using anything but gelcoat or the laminating resin itself as an initial coat that will provide a durable, attractive outside layer after demolding?
Dinoa
Old 01-23-2010, 02:10 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
I have seen it used as well, but with PU paint. Also I have some PU gelcoats for epoxy in my program, so I guess it can work.
You do need a 100% perfect mold, however.
Alternator alternative?? steveroo OnBoard Electronics & Controls 13 01-01-2010 12:59 PM
Alternative propulsion Wemdoug Propulsion 2 01-01-2010 07:01 AM
Alternative fuel. rayk Open Discussion: All Things Boats & Boating 57 04-24-2008 04:34 PM
Rhino alternative CGN Software 4 01-15-2007 03:42 AM
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
