| gelcoat Does gelcoat offgas? if so, for how long? |
| About quite some time. Minimum a fortnight. Can be in reality much longer. |
| about two weeks. warm temp shortens the time |
| Bricker, One of the main components of polyester is a volative chemical called styrene. Styrene is what's responsible for that characteristic "fiberglass smell" of poly- and vinylester composites. Most of the styrene becomes part of the cured laminate/coating, but some evaporates during and after applying it. So, the simple answer after this convoluted preface is; If it smells like styrene, it's offgassing. I should also say that the base polyester resin in gelcoats, laminating resins, putties, etc. is pretty much the same thing. For you experts out there, yes, I know that this statement glosses over a lot of subtleties, but in this case I think it's good enough for government work. Yoke. |
| Spraying gelcoat over gelcoat | alexhiguera | Fiberglass and Composite Boat Building | 9 | 08-26-2005 11:09 PM |
| Gelcoat project on 71 Shark | LtsGo4ARide | Fiberglass and Composite Boat Building | 4 | 07-03-2005 11:02 AM |
| Clear Gelcoat | Dawgfish71 | Materials | 8 | 04-05-2005 01:33 AM |
| Gelcoat (sanding) | Saeed | Fiberglass and Composite Boat Building | 3 | 02-16-2005 04:35 PM |
| Gelcoat over Epoxy | wet-foot | Boat Design | 9 | 08-16-2004 07:58 PM |
