Old 01-07-2005, 02:01 PM
JamesR
GelCoat
Is there any need or reason to put on vinylester gelcoat on a fiberglass boat? Or is polyester gelcoat usually fine? This would be to help keep blistering off of the vessel, mostly on the above water line area. The bottom will be coated with epoxy barrier coat.
Thanks
JamesR
Old 01-07-2005, 07:19 PM
tja tja is offline
Rep: 11 Posts: 125
tja
Generally speaking the only part of the boat that will blister is below the water line. Run your epoxy barrior coating a couple of inches above the actual water line and that should do just fine. What type of antifouling are you planning to use?
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
Gelcoat project on 71 Shark LtsGo4ARide Fiberglass and Composite Boat Building 4 07-03-2005 11:02 AM
Clear Gelcoat Dawgfish71 Materials 8 04-05-2005 01:33 AM
Gelcoat (sanding) Saeed Fiberglass and Composite Boat Building 3 02-16-2005 04:35 PM
Gelcoat over Epoxy wet-foot Boat Design 9 08-16-2004 07:58 PM
