| gelcoat How many coats of gelcoat should I apply? Does it need to be sanded between? I plan to roll it on. Will the gelcoat run a lot if I apply too thick? can I avoid this? I an repainting the outside of a small dinghy and want to know what grit I should start with to sand/polish. does it have to be wet? well, that ought to get me going. . . anything else I should know? thanks in advance. p.s. I preped with 80 grit is that course enough? still looks fairly smooth & shiney. |
| use the search on this site and you will find alll u need to know |
| gelcoat help? | SCUBAnut | Materials | 7 | 01-11-2007 08:29 PM |
| Gelcoat help | pappastratos | Boat Design | 0 | 06-19-2006 11:02 PM |
| Spraying gelcoat over gelcoat | alexhiguera | Fiberglass and Composite Boat Building | 9 | 08-26-2005 10:09 PM |
| gelcoat | Jorge | Wooden Boat Building and Restoration | 8 | 08-25-2005 06:24 PM |
