| Gel Coat vs Bed Liner I'm in the process of designing a Polystyrene marsh sneakboat for duckhunting. I of course plan on using epoxy resin and will have to coat it. I'm debating on using bed liner vs gel coat due to it's toughness. I'm guessing bed liner will weigh more, but offer more protection. Any input on this would be much appreciated. Thanks! |
| Since gel coat doesn't bond all that well to epoxy you can scratch it off the list of options. |
| Truck bed liner coatings are specially formulated, modified polyurethanes. They aren't high gloss and chalk up pretty quickly in most colors. They tend to go down heavy (30 mils plus) and you need to spray the high cyanoacetate formulations (special guns) with care, if you want a smooth finish. You can paint over them, but the dramatic difference in film elongation, will likely cause issues on a boat. I'll second the paint option, as it's the economical method with easily obtained, spectacular results. This isn't true with both gel coat and truck bed liner. With some skill, well controlled conditions and an experienced sprayer, you can get a very good gel coat job, but this would be a rare thing from a shade tree type of situation, that the typical home builder would produce. |
| id buy a truck for my bedliner hehehe hiya par niceseein you again ; }
__________________ hehe ,,,,,Jim------> |
| when you say coat I assume you will be using epoxy resin to wet out a reinforcing fibre cloth (otherwise it will be brittle/useless IMO and then the PU Bed liner coating is the way to go after that is all nicely sanded up !! |
| ondavr , just curious what is so complicated about it........ considering most areas or any surface that needs to be painted usally will require a Primer prior to painting which most likely will be a primer that is recomended by the manufacturer of the paint but then again there are a lot of primers out there...... that are compatible with just about everything . Hey guys , my neighbor, is in his late 70's has been painting is duck boat with Sears Weather beater for the last 30 years which really does not look that bad ,and if cost is that big of a concern ,and something as simple as prepping a project for paint (Primer).............................why not . |
| Special order it, have it shipped (hazardous material $$), catalyzed with an application window, etc. |
Done ................ ![]() |
| Seems a large part of the problem is spraying, most of the products use 30,000US plural component spray equipment. Also getting a smooth surface may be impossible? http://www.youtube.com/watch?v=njsZW...eature=related http://www.pickupspecialties.com/Bed...bed_liner.html www.rhinoliningsindustrial.com other info pick-up online: Polyurea elastomer systems are amorphous in nature, not crystalline like polyurethane systems. This amorphous nature is similar to that of epoxy type systems except that polyurea system do not have a true glass transition temperature. What's the difference between aromatic and aliphatic polyurea systems? The typical aromatic polyurea systems must be processed through high pressure, heated plural component pumps and sprayed through an impingement type spray-gun. This is true also for the aliphatic version of this type of system, the primary difference being the color stability of the aliphatic systems. Actually there are two different types of aliphatic polyurea systems currently on the market. One is the typical high pressure/temperature sprayed systems and the other is what is known as a "polyaspartic polyurea" type system. This polyaspartic system is different in that it uses an ester based resin component and has a longer pot life. It can be hand applied using close nap rollers; brushes; rakes or even airless sprayers. The aspartic systems are not the high build coating typical of the "hot spray" polyurea systems. How should polyurea be prepared for overcoating after initial cure of the polyurea? Prior to overcoating polyurea make sure it is clean. For the first several hours after polyurea has gelled it may be suitable for overcoating without further preparation. If polyurea base coat material has been in place for longer than six hours there could be problems with inter-coat adhesion. Since fewer products are carried in aromatic solvent, which tacktify polyurea you must undertake this process. To assure inter-coat bond apply a liberal amount of denatured alcohol (or more aggressive solvent such as acetone or MEK) to polyurea and allowed to evaporate completely. This will re-tack the polyurea base coat and allow proper adhesion of the follow-on overcoat. This same procedure should be used when bonding polyurea to polyurea after initial cure has taken place. |
Not negative, just realistic. He can go down to the local hardware and store buy primer and paint that will work fine on a project like this for a fraction of the cost of buying gel coat and a suitable primer for good adhesion to epoxy, and that's before the cost of shipping. |
| I appreciate all of the responses thus far. I guess there might be some questions why I am asking about bed liner. I guess I should have mentioned a little more about what I'm doing, this post may illustrate. The boat I am going to build will be much more...sexy. I'll have nice lines, conduit for wiring lights, switch panels, sub-floor, etc...basically a dream duck hunting layout boat. I plan to build it this coming off-season to have ready for 2012-2013. I really don't care about cost. If I wanted cheap I'd just buy another boat like mine off Craigslist for $400 and call it a day. The reason I am asking about bed liner is we have to break ice often when duck hunting here in NW Missouri. Something I've done plenty of times with my current layout boat that uses polyester resin. I don't have any cracks or leaks (that I'm aware of) from this...yet. However, I know that epoxy is stronger and it won't melt polystyrene. From the responses thus far, paint is cheaper, easier and only offers aesthetics and UV protection. Bed liner is more expensive, requires more prep and offers more protection than just UV but often fades in color to a gray. The boat will be completely covered in grass and sloshed in mud. I doubt anyone would see that. Am I correct in my thinking that a commercial application (line-x/rhino liner) would be preferred over Herculiner? Ondavr: You're right, I'm using epoxy to wet out fiberglass. |
| That helps a great deal. You can use paint on the topside and a truck liner type product on the bottom if you think it will be subjected to a great deal of abrasion. Use a very flexible brand though, some are rather stiff and may crack or chip. They can also be heavy, so don't over do it. |
| gel coat,...who needs it!!!! | roscoewalsh | Fiberglass and Composite Boat Building | 11 | 09-02-2009 09:33 AM |
| Gel coat | nrodes | Materials | 13 | 01-25-2009 10:54 AM |
| gel coat | alfiej44 | Fiberglass and Composite Boat Building | 10 | 09-05-2008 06:16 AM |
| gel coat instead of toolin gel ? | meredog | Fiberglass and Composite Boat Building | 5 | 08-10-2006 08:53 PM |
| polyurathane bed liner | overshoot | Wooden Boat Building and Restoration | 1 | 02-28-2006 11:29 AM |
