| Gel coat question I recently bought a 1987 21' Bayliner Trophy Hardtop. After making repairs that I knew were needed steering cable, replace outdrive, and fixing rub rail molding I noticed that there was a lot of caulk on the underside of the rubrail. I then walked around the boat hitting the sides with my hands. It appears that the gel coat may be loose from the fiberglass on both sides. The transom and about 7 feet from the bow back appear solid. Is this a major structural issue? The hull itself seems strong and there are no soft spots anywhere on the boat. Any suggestions or help would be greatly appreciated. thanks , Bobby |
| The gelcoat is maybe 1/8" thick or so. If it comes loose it will crack and fall off. Delamination is a serious structural issue. You need someone knowledgeable to inspect your boat.
__________________ Gonzo |
| gel coat Thanks Gonzo; The gel coat is in tact. Someone told me that it is possible that where the upper and lower part of the boat are put together may have seperated. I am going to take the rub rail off and look to see if I can tell whether or not this is the problem. bobby |
| gel coat,...who needs it!!!! | roscoewalsh | Fiberglass and Composite Boat Building | 11 | 09-02-2009 09:33 AM |
| Gel coat | nrodes | Materials | 13 | 01-25-2009 10:54 AM |
| gel coat | alfiej44 | Fiberglass and Composite Boat Building | 10 | 09-05-2008 06:16 AM |
| gel coat instead of toolin gel ? | meredog | Fiberglass and Composite Boat Building | 5 | 08-10-2006 08:53 PM |
| Gel coat | jeremyb251 | Materials | 1 | 03-16-2006 12:40 AM |
