Old 01-06-2006, 10:02 AM
Smartbomb Smartbomb is offline
Wooden Boat Enthusiast
Rep: 10 Posts: 6
Gel coat book or guide
Can someone recommend a good gel coat book or guide? I'm not coming up with many resources through internet searches. I'm not new to fiberglass but I am new to gel coats and I want to do a good job. I'm in the planning stages of creating a one-off, cold-molded power cruiser that will be glassed, and ideally gel-coated, no molds to speak of. My current thinking is to use Duratec in a spray gun, thinned down 1:1 with Duratec gelcoat thinner, as I saw on this thread. It's a topic that's mystified me for quite some time and I'd like to make sure I have the appropriate tools and technique, perhaps even experiment a bit before I go at it on my hull.
Thanks for any info you can provide.
Old 01-06-2006, 01:08 PM
AVMan AVMan is offline
Rep: 12 Posts: 30
Gel coat spraying
For a guide on good gel coat spraying, try the CCT guides/manuals from ACMA (www.acmanet.org). They have a "Controlled Spraying" technique book available in their book store. I also remember CCP having a pretty decent materials guide, but I haven't seen one around for a while....
gel coat instead of toolin gel ? meredog Fiberglass and Composite Boat Building 5 08-10-2006 08:53 PM
Rolling Gel coat on the hull bottom?? Gamble Fiberglass and Composite Boat Building 5 11-09-2005 10:11 PM
milky patches in clear gel coat still afloat Fiberglass and Composite Boat Building 3 07-22-2005 03:29 PM
Gel Coat vs Fiberglass pramdx Fiberglass and Composite Boat Building 6 07-18-2005 06:44 PM
epoxy to gel coat bonding Guest portpenncrab Boat Design 1 10-22-2003 07:44 PM
