Old 03-02-2010, 03:39 PM
osborn159 osborn159 is offline
Rep: 10 Posts: 8
garage floor paint on deck??
was going to get resing for the project and thinking about things to come, i have a kit of two part epoxy garage floor paint left from the garage project, has anyone used it on a boat deck, how durable? opinions/experiences???
Old 03-02-2010, 06:37 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
epoxy two pack is Ok , if costs are an important factor and you have some already, use it.
Old 03-02-2010, 06:57 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
It will work, but most say on the label they're not designed for outdoor use. The reason is that epoxies don't hold up all that well in sunlight, it may turn yellow and chalk much sooner than other products.
Old 03-03-2010, 10:15 AM
kim s kim s is offline
Rep: 42 Posts: 70
garage floor paint
I used 2 pack epoxy floorpaint which was cleaned using water,!!!! I know sounds strainge but you could thin it down with water as well.
I sprayed all under the deck head of a small boat I had, painted the decks and cockpit with it ---oohh the other thing, the ply wood was just standard outdoor ply, NOT ,marine ply.
Well 3 years on and the boat has been left out in all weathers, slung into the back garden and has not been moved the last year and the ply is still good with no signs of delam.
Kim
I take no responsibility though for any one who is brave/stupid as I was, if it dont work
Old 03-04-2010, 07:47 PM
jonr jonr is offline
Rep: 34 Posts: 246
Try and cover it with something more UV resistant - like spar varnish or polyurethane.
Old 03-04-2010, 08:43 PM
Landlubber's Avatar
jonr,
many of the flooring epoxies are uv resistant, the manufacturer can advise otherwise.
Old 03-05-2010, 12:08 AM
Rep: 10 Posts: 8
I painted my garage floor with the product a year ago, have a strip outside of the garage door about 10" wide exposed to the elements seems to be no worse for wear than the interior part. i still am not convinced i may or may not. see how things look when i get to that stage.
Old 03-05-2010, 02:01 PM
Rep: 34 Posts: 246
This may not apply to water based epoxys, but from the West site:
It is important to realize, however, that while pigmented epoxy may be somewhat more UV resistant than unpigmented epoxy, pigmented epoxy should still be covered with a UV resistant coating, either clear coat or paint, to protect it from UV radiation for outdoor applications.
Old 03-06-2010, 12:16 AM
Rep: 10 Posts: 8
as a footnote to this whole discussion i have decided against using this on the deck, as i remember this paint only had about a 1 hour potlife, fine if 2 people are painting a garage floor. standing aft of the boat i realised the cut in alone would take that more or less, so i will search for another option, thanks for all the input none the less.
D
Old 03-11-2010, 10:40 AM
Steve Clark's Avatar
Steve Clark Steve Clark is offline
Charged Particle
Rep: 153 Posts: 118
I have used PPG AquaPon for years with good results.
Doesn't do shiny, but is durable and tough.
Cleans up with water.
SHC
Beatings will continue until morale improves.
Paint type best to cover texured fibergalss deck and catwalks northrivergeek Boat Design 3 02-24-2009 12:41 AM
Boat Floor Paint.. ahasiec Fiberglass and Composite Boat Building 2 01-05-2006 12:26 AM
Topsides & Deck Paint Question Chris Krumm Materials 3 08-27-2005 07:44 PM
Paint for Patterned Non-slip Deck jonboy834 Fiberglass and Composite Boat Building 7 08-13-2004 10:51 AM
