Old 03-18-2008, 07:43 AM
rossgiles rossgiles is offline
Rep: 10 Posts: 3
Free of charge, Steel - polyurethane foam -Steel insulation sheets
Hi to all,
May be this may be of interest to some of you, for boat building projects you may have on the go.
It's from ebay listing no. 140214120403
We have approximately 15 tonnes of used insulation boards at our Dudley (west of Birmingham) site that we are prepared to give away FOC so long as you organise the collection. They have been used as cold store room panels, but could also be used for insulation in many building applications (roofing or panelling). 1mm thick steel facings on both sides (NOT foil) - so will require a saw to cut up. Assorted lengths as per picture. Insulation in sandwich is polyurethane foam, although we have about 2 tonnes of fibreglass panels (also steel faced) in 30m uncut lengths.
Foam for Insulation, not structure pairomedicsfish Materials 5 07-06-2006 09:28 AM
Polyurethane Foam install Ok J Fiberglass and Composite Boat Building 5 04-20-2006 03:45 PM
Welding polyurethane foam and such... jprev Boatbuilding 11 01-31-2005 11:28 PM
foam filler for steel barge Sue Fox Metal Boat Building 5 11-29-2004 08:18 PM
new free design & building project: YAGO 31' steel origami yawl yago Boat Design 1 08-21-2004 01:42 AM
