Old 08-25-2007, 08:35 AM
pescaloco pescaloco is offline
Rep: 67 Posts: 243
foam sheet - wet slurry question
hey guys,
just wanted to get a clarification on some great advise from a past post of mine. I will be doing a lot of glass work on a male mold using sheet foam core.
it was suggest to use a wet slurry on the foam panels.
it is all hand work with polyester and "no" vacuum bag
the question is there is a lot of verticale surface work, the sheet is primed with catalyised resin, is it necessary to make a low viscosity putty / slurry and cote the core face and let kick off, or just use the slurry and start the lamination process.
thanks, mark
Hull Flotation Foam Question bobby4244 Materials 14 06-11-2009 03:54 PM
foam core glassing question pescaloco Fiberglass and Composite Boat Building 13 11-03-2006 10:43 PM
sheet PVC John P Materials 2 12-19-2005 06:52 PM
Foam question wes_mcgee Fiberglass and Composite Boat Building 8 10-13-2005 08:16 PM
Wet foam stringers don1113 Materials 4 08-09-2005 05:24 PM
