| Foam/fiberglass VS Plywood Hey everyone, this is my first (of many most likely) post. I obtained an old 14ft aluminum V-Hull fishing boat and trailer for free from my dad who has had it sitting around forever. since he has a 16ft one that he has all geared up. As of right now the boat is pretty much stripped it is an aluminum shell with some old weathered plywood making a sketchy deck platform and back bench seat. basically a project that was started years ago and never finished. My plans with the boat are to make a much smaller deck (front 1/4 of the boat) some side storage bins, a couple swivel seats and a rear bench with compartments for the fuel tank and battery. I was originally planning on pulling out all the existing wood and replacing it with new, water seal treated wood and carpeting it. the problem I see, is that this hull isn't all that deep and I dont want to add a bunch of extra weight especially since my fishing buddy is a 6'4" tall 330 lb manchild. Now, I have never fiber glassed anything before, which makes me kinda want to do it instead of wood that much more but I was thinking I could get me some nice sheets of the blue or pink insulation foam from [insert local hardware store here] and build out the framing for wverything, then gey some of that nifty A/B Poly expanding foam and fill in every thing, once that all cures up nice I would shave and sand it all smooth then resin it and lay a bunch of CSM fiberglass matting maybe 3 or 4 layers of mat? the either carpet or gel coat it.I figure it would be lighter than wood, and virtually unsinkable. on the other hand I could be horribly wrong and end up swimming back to shore. I plan on taking pics of the entire process either way I go ahead with this. thanks in advance for any advice/suggestions |
| It might be worth doing a search of the forums for the other dozen threads that wanted to do a similar thing. The first things that might produce a possible disappointment are the words "CSM fiberglass matting maybe 3 or 4 layers of mat?" and "I figure it would be lighter than wood" |
| brand new foam core plywood with fiberglass cloth one piece deck | WickedGood | Marketplace | 0 | 05-16-2010 07:10 AM |
| brand new foam core plywood Deck with fiberglass cloth | WickedGood | Marketplace | 0 | 04-18-2010 08:29 AM |
| Combining Foam and Plywood construction in the Same Hull | CET | Boat Design | 21 | 03-11-2006 12:25 PM |
| Foam/Plywood boat plug construction ?s | cla17 | Boatbuilding | 22 | 05-21-2005 02:44 AM |
| Foam / Plywood Boat Plug Construction ?s | cla17 | Materials | 2 | 05-18-2003 06:45 PM |
