Old 07-17-2011, 08:26 AM
idkfa idkfa is offline
Rep: 66 Posts: 232
Maybe this might be useful - HullScant
http://www.wumtia.soton.ac.uk/software.html
Old 07-17-2011, 08:38 AM
rberrey rberrey is offline
Rep: 69 Posts: 287
I will write some of what Ed Horstman says in his book ( Foam Fiberglass Sandwich Construction).Structurally speaking if you double the thickness of the foam you obtain approximately 4 times the bending strength and approximatly 8 times less deflection. Structully it is best to use a thicker material first and a higher density second if in doubt. Never go below 4lb density. Add 10% to the outer laminate to compensate for the extra abuse it receives Structurlly both surfaces carry basicly the same load but theouter is subject to abuses like scratches. rick
Old 07-17-2011, 11:26 PM
sailingdaniel sailingdaniel is offline
Rep: 20 Posts: 50
Two more good advice.. Thanks rberrey and idkfa..
I might be able to get some of the books in Southafria , here in Mauritius i cant..
RXcomposit . I have sent u a message aboute a frend that might want to build a Cat in Phillipines, Not sure if that would be interesting to u?
Fibreglass sandwich construction, core? watchtherocks Fiberglass and Composite Boat Building 25 03-13-2010 01:33 AM
25 yr old foam sandwich constructed sailboat jksoft Fiberglass and Composite Boat Building 3 07-27-2007 08:30 PM
Sandwich wood core strenght TomE Materials 17 09-26-2005 10:39 PM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 06:00 PM
Very interresting link about Composite sandwich core jfblouin Boat Design 1 03-08-2005 10:23 AM
