Old 06-12-2009, 10:08 PM
Highwater Highwater is offline
Rep: 10 Posts: 5
Foam core in a female mould
I am looking at building a 12' outboard dinghy. I want to cut the bottom and side panels and set them in a building jig to make a female mould. I want to use epoxy/glass in the mould, then foam, then epoxy/glass. This way I don't have hours of filling and fairing.
What do I coat my mdf female mould with so the epoxy does not stick?
Would laminex do the job better than mdf (but it is expensive)?
Other than vacuum bagging, how do I get a strong bond between foam and glass/epoxy? Use weight, turn hull on its side and use weights?
Can anyone direct me to a plan for a foam/sandwich dinghy of 12' that takes up to 15hp?
Mike
Old 06-14-2009, 03:40 AM
AndrewK AndrewK is offline
Rep: 338 Posts: 372
Highwater,
Unless you are going to use vacuum I would not bother building a proper mold.
I would make a batten mold with say 5 stations, wire and screw the foam panels in position, glass oneside remove from mold and glass the other. Reinforce the sheer by glassing a timber batten to the outside, install the seating and thats it.
A friend made one using 6mm foam and 450gDB and polyester resin, this has turned out to be an excellent dinghy.
Attaching foam to a mould b_rodwell Fiberglass and Composite Boat Building 1 12-16-2008 06:18 AM
Top Coat Material for serial production with epoxy and female mould emresandan Fiberglass and Composite Boat Building 4 08-04-2008 01:45 PM
Lightest layup for a female deck/coachroof mould Roly Fiberglass and Composite Boat Building 2 10-12-2006 01:14 AM
Which Foam for Core? Toby P Fiberglass and Composite Boat Building 5 05-06-2006 06:44 PM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 11:12 PM
