Old 05-02-2006, 07:18 AM
Toby P Toby P is offline
Rep: 40 Posts: 42
Which Foam for Core?
I am looking to build a 4.3m (14ft) sailing boat of moderately high performance. It will be sailed mostly on lakes, with the occasional outing on the sea - so fairly low loads. I am thinking of using foam sandwich construction - but which foam should I use? Airex, Corecell, Divinycell or anything else? What are the advantages and disadvantages of each? My priorities are for the boat to be light, long lasting and not overly expensive.
Many thanks.
Old 05-02-2006, 07:48 AM
antonfourie antonfourie is offline
Rep: 13 Posts: 169
Have a look at this site for more details on foam cores
http://www.netcomposites.com/education.asp?sequence=45
Old 05-02-2006, 08:14 AM
Rep: 40 Posts: 42
Thanks Anton, there is some useful stuff there. However, most of the articles seem to be written by SP, hence the slight bias about SAN foams.
I definitely want to go for a SAN foam like Corecell, or a PVC foam but I wondered what the most popular ones at the moment are.
Divinycell, Klegecell, Airex etc all seem to be similar stuff - which is the best?
Old 05-02-2006, 08:50 AM
Rep: 13 Posts: 169
That depends alot on money and what is avilable where you are. I did have some data comparing all of them, but it is not on this PC (work PC), I think that Airex came out best in the money vs strength vs workability
Old 05-06-2006, 06:39 PM
jimslade jimslade is offline
Rep: 14 Posts: 304
Check out Nida core. I've had good success using it.
Old 05-06-2006, 06:44 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
For your purposes, Airex will be a pain, since it cannot be sanded easily, and therefore must either conform perfectly to the shape, or be kerfed and thus heavier (resin sits in the slots...)
Corecell or balsa would be the best bet. I know balsa gets a bad rap, sometimes deservedly, but it is still good stuff when used properly (i.e. NEVER, NEVER drill through a balssa-cored laminate - use it where there will be NO HOLES and use foam in the holey areas.)
In the shop, we use Corecell or balsa exclusively for sandwich structure, and Divinycell for anything that is less important.
Steve
PU foam VS Core-Cell or other? Danielsan Fiberglass and Composite Boat Building 18 07-17-2006 08:42 PM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 11:12 PM
Selecting foam core TomE Materials 14 01-07-2006 05:18 AM
Foam core Hotrod99 Fiberglass and Composite Boat Building 9 09-06-2005 02:24 PM
AIREX Foam core Brad Seger Materials 3 07-28-2004 01:36 PM
