Old 07-24-2005, 09:41 PM
IHTFP IHTFP is offline
Rep: 10 Posts: 32
Foam between buttress supports
I am currently in the middle of a restoration of a small speedboat. When finished, my hull will look like the one in the picture. Originally, the boat had foam in between the buttress supports that run from the stringers to the hull sides. Should this foam be replaced? What are the pros and cons.
Thanks for the help
Old 07-24-2005, 09:44 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
How do I get to your picture?
Old 07-24-2005, 10:14 PM
Rep: 10 Posts: 32
The picture should be attached to the post. If not, here is the link to the picturePicture
Old 07-24-2005, 10:23 PM
Rep: 1397 Posts: 7,216
The foam is both structural and the required legal floatation. Use a pourable closed cell foam.
Old 07-24-2005, 10:25 PM
Sounds good to me.
Old 07-25-2005, 08:46 PM
Rep: 10 Posts: 32
Gonzo,
Is there a reference that you can point me to that would have all the floatation, electrical, etc regulations that I will need to follow when I am rigging the boat. I assume that you are referring to USCG regulations in your post about the floatation.
Thanks
Old 07-26-2005, 08:32 AM
abyc.com
Old 07-26-2005, 08:33 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Here is a .doc I got from USCG, it should give you the info that you need.
Steve
Old 07-27-2005, 08:46 PM
Rep: 10 Posts: 32
Great Resources, thanks for the help.
Old 08-07-2005, 10:16 AM
Rep: 10 Posts: 32
My plan is to fill the void between the hull and the supports with foam and then fiberglass them shut so no water can ever enter the void. Does anybody see a problem with this? or should I be able to keep the void unsealed?
Thanks for the help
Old 08-07-2005, 05:33 PM
Normally you install the plywood deck, cut holes to pour the expanding foam in and them fiberglass over everything.
Old 07-16-2006, 04:37 AM
Rep: 10 Posts: 32
If I seal the foam filled void with fiberglass, is there any reason to drill the limber holes for drainage just in case some water gets in there? Theoretically sealing it up with fiberglass should stop any water from getting in, but in reality, who knows what will happen. Should I put in the limber holes just in case?
Thanks for the help
Old 08-01-2006, 12:30 AM
Deeman's Avatar
Deeman Deeman is offline
Rep: 10 Posts: 50
My boat had what looked like a one piece sealed deck and cuddy, sealed solid and filled with foam and NO limber holes, from the factory in 1982. Well 24 years later I found her foam full of water without anyway to drain except by excavating the foam and rotted stringers. So, in the rebuild, mine will have limber holes leading to the bilge. They won't hurt and the next owner will be real happy. http://www.boatdesign.net/forums/ima...es/biggrin.gif
Eric
The whole story
Airex and any foam based hull materials tdamico Boat Design 21 03-04-2009 08:26 PM
Pourable foam, need advice BustedKnuckle Materials 6 07-10-2006 09:19 PM
Foam Block To Bass Boat... can this be done? Curious Fiberglass and Composite Boat Building 10 12-11-2004 07:21 PM
Positive Buoyancy Floatation foam & Ullage Equation trouty Boat Design 2 07-02-2004 10:29 AM
Foam / Plywood Boat Plug Construction ?s cla17 Materials 2 05-18-2003 07:45 PM
