Old 05-16-2010, 01:16 AM
alyeska alyeska is offline
Rep: 10 Posts: 12
Flowcoat
Can polyester flowcoat be applied over epoxy laminate or am I better off mixing some pigment into the epoxy for a sealing coat?
Old 05-16-2010, 09:12 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
No, the bond will be poor, mixing pigment in to epoxy helps a little, but its not sufficient to stop UV degradation. Use a paint, it will be low in cost and work very well.
But then it also depends what you plan to use this item for.
Old 05-16-2010, 09:25 AM
apex1
May I add (and correct a little):
pigment helps NOT, the EP will still deteriorate under UV at the surface.
Instead of paint, UV protecting varnish can be used as well. And that must not be the expensive PU stuff.
As mentioned, much depends.........
Regards
Richard
Old 05-16-2010, 09:35 AM
Rep: 288 Posts: 662
Actually pigment does help a little. The UV rays are blocked before they can penetrate deeply into the surface when high pigment concentrations are used. This means degradation of the surface will still takes place, but the epoxy below the surface is affected less than it would be without pigment, so it can take longer for it to breakdown.
This is not a good solution, but it does "help a little".
Old 05-16-2010, 12:39 PM
apex1
Well, yes, a little.
But neither you, nor me would recommend it! After a while it would make trouble due to further degradation.
Old 05-16-2010, 02:23 PM
Rep: 10 Posts: 12
The application is for a locker under the cockpit floor so uv not an issue. My main concern was the bonding of the two differen't types of resin, sounds like it won't be good so I will use the pigment or paint option, only thought of flowcoat as I have some available.
Old 05-16-2010, 03:16 PM
apex1
The bonding will not happen! (or at least not sufficient)
The pigment option was already handled by both of us! Leave it.
Apart from UV degradation any unproven "filler" can change the desired properties of your expensive epoxy layup. So, do´nt risk that, paint it with some exterior house paint!
Yes, that was meant seriously, ext. house paint on EP, that is usually sufficient for your application.
And, it might be impressive to discover, how much light (incl. UV) one can find beneath a cockpit floor. I once had a architectural drawing stowed in a drawer with a ventilation grille, the cabinet was not far from a tiny, transparent solar vent of about 3 in. diameter. After about 2 years the front page was almost plain yellow due to UV light!
Good luck
Richard
Old 06-27-2010, 06:35 AM
Samnz Samnz is offline
Rep: 42 Posts: 196
if the epoxy is sanded with 80 grit would this provide enough of a key for the gelcoat? I was thinking of using gelcoat/flocoat in my epoxy/ply/glass anchor locker. I know polyester wont stick to epoxy chemically but what about the mechanical bond? has anyone tried this?
Old 06-27-2010, 06:50 AM
apex1
It still is a poor bond and prone to failure.
Regards
Richard
Old 06-27-2010, 07:22 AM
missinginaction missinginaction is offline
Rep: 417 Posts: 336
I used this over the new epoxy in my engine compartment. I was very pleased with the results.....
http://www.yachtpaint.com/usa/diy/pr...bilgekote.aspx
MIA
Old 06-27-2010, 07:56 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,597
I don't know anything about this stuff it looks like it might be good. Googled "epoxy gelcoat". This is a polyester formulation designed for use on epoxy substrates-from the UK. Anyone know anything about it?
There are a few other companies...
http://www.scottbader.com/downloads/...re_English.pdf
yes, it is a revolution
Old 06-28-2010, 02:35 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I would recommend an epoxy coating of some sort. If you were to knock on my door I would give you a set of ecoProtect from ecoLine Coatings, but there are many more.
Epoxy compatible gelcoat does not work. It only works the other way round.
However, there are some types of epoxy that do allow polyester topcoat over it, with enough adhesion to survive. Ideal for repairs.
Old 06-28-2010, 08:48 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Put simply DONT MIX RESIN TYPES !!
