Old 06-18-2010, 12:26 PM
brokensheer brokensheer is offline
Rep: 14 Posts: 108
floral foam
I have heard that the green foam used in the florist undustry will not react with polyester resin can anyone confirm this
Old 06-18-2010, 02:49 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
True, it is a phenolic, but it is relatively expensive as well. You are better off using EPS foam or even PU foam.
EPS foam can be coated with epoxy, or even with polyester when sprayed on in light mist coats, or with a polyester called "EPS-Coat" which is available in The Netherlands from Brands Structural Products.
Old 06-18-2010, 10:13 PM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 553
I bought some for a dollar out of desperation when I had to patch a dinghy. The stuff worked beautifully!
Old 06-19-2010, 01:11 AM
Herman's Avatar
Resininfusion.info
For the exact application, I once used a (free) newspaper and a piece of tape. Worked wonders as well, and saved me a dollar!
Old 06-19-2010, 02:10 AM
mark775
Tinhorn, I follow you in the first and second pics - what are we looking at in the third? What are the white pieces?
Old 06-19-2010, 08:04 PM
tinhorn's Avatar
Rep: 272 Posts: 553
Rats. I'll never get that dollar back.
The third pic is out of sequence--I patched the edges of the boat separately from the corner. The while strips are cheap plastic trim from Lowe's. REAL tightwads would probably use rolled-up newspaper.
Sheesh--in reviewing my pictures, they're in exact bass-ackwards order.
Old 06-19-2010, 11:21 PM
Herman's Avatar
Resininfusion.info
Yep, real tightwads would.
Nearby there was a company using a lot of polyester resin. I bought it cheap there. They had a 20 liter (5 gallon) pail, which they filled for me. They did not have the lid, however. So I was driving around with an upen bucket of polyester resin... Did not go wrong, luckily...
Old 06-20-2010, 03:17 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
I bought the first patch of polyester for my little boat project. The guy gave it to me in a 10 liter plastic bucket. I didn't want that in my car so we taped a plastic shopping bag on top as a lid.
The floral foam is designed to absorb water, so don't leave it in the boat.
L
Hopefully creating something useful, since 1983.
Old 06-20-2010, 08:37 AM
tinhorn's Avatar
Rep: 272 Posts: 553
I would have taped newspaper over the top of the bucket.
Old 06-20-2010, 10:01 AM
Herman's Avatar
Resininfusion.info
You guys are just so smart! Never thought of that.
Oh, I mixed my first batch in a coffeecup...
Old 06-20-2010, 10:04 AM
apex1
Proost!
Old 06-20-2010, 01:19 PM
Herman's Avatar
Resininfusion.info
there was not even time for "proost" as the cup melted away just after i mixed in the hardener...
Old 06-20-2010, 06:31 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Polistirene coffee cup ? Rinse it with petrol first next time That'll get you melting !
You get some PE clossed cell foams that works with polyester. Easy to work with and will add a bit of booyancy, but not as cheap as newspaper or those floral foams. Good grief... newspaper ?
I get scared sometimes when I see what some people go on the water with. 'Saving' a couple of $ doesn't help much if you get in trouble. Buy those closed cell PE foam sheets and glue them inside the boat. They are nice to the touch, great insulation features, different colours and most of all, whan the paw-paw hits the fan you live to tell.
Regards
Fanie
Water ! Just gimme water !
Old 06-21-2010, 04:29 AM
Herman's Avatar
Resininfusion.info
Newspaper has the same structural value as flora foam. However, with a bit of packing tape and creativity it lends itself for temporary molds.
Another nice solution that I saw was a plumber that needed to solder a connection in a water pipe. The pipe kept leaking water, however. He took a slice of white bread, kneaded it into a ball, and jammed it in the pipe. This stopped the leaking, and he was able to make a nice joint. The water pressure after opening the main valve washes away the bread.
On newspaper again: I have seen boats being reinforced by rolled newspaper, with laminate over them.
For trailer moulds for dinghyes I used the foam tubes they sell for insulating water pipes. Cut them in half, and they make a nice former for a stiffener. Never had any problems, but I must admit the application was very low-tech.
Old 06-22-2010, 10:08 AM
Rep: 14 Posts: 108
I have to make a plug of an object that has curved sides I am not familiar with the abv. Herman. this is a carolina/florida style console pod.
Where to get foam? Chris Ramsey Boatbuilding 6 05-24-2010 04:23 PM
About that foam? 360weatherbound Boat Design 12 03-29-2010 06:05 PM
To Foam or Not to Foam? 4winns Materials 9 06-30-2009 11:43 PM
How much foam huntermike32 Wooden Boat Building and Restoration 1 10-18-2005 07:59 AM
Name That Foam!!! kudu Materials 9 01-19-2004 10:44 AM
