Originally Posted by Herman Newspaper has the same structural value as flora foam. However, with a bit of packing tape and creativity it lends itself for temporary molds. Another nice solution that I saw was a plumber that needed to solder a connection in a water pipe. The pipe kept leaking water, however. He took a slice of white bread, kneaded it into a ball, and jammed it in the pipe. This stopped the leaking, and he was able to make a nice joint. The water pressure after opening the main valve washes away the bread.
On newspaper again: I have seen boats being reinforced by rolled newspaper, with laminate over them.
For trailer moulds for dinghyes I used the foam tubes they sell for insulating water pipes. Cut them in half, and they make a nice former for a stiffener. Never had any problems, but I must admit the application was very low-tech. |
Stopping the water with white bread is a time-honored trick. I learned it from a plumber myself about thirty years ago, and he told me he learned it from his father.
