| Floor Project Good afternoon all! I am currently replacing the floor in my 17.5' VIP Vision, I have removed the rotted glass covered plywood, water soaked foam, and one section of a stringer that was rotten. My question is should I use marine grade plywood for this project? And will the resin soak into pretreated marine grade plywood? |
| Hi sparky This is one of the comon question around this forum. You should try searching the site, plenty of info in it (floor, tramson, stringers...). Also here is a place you might want to check and get back here for questions. http://www.rotdoctor.com/glass/GLrotrepair.html Good luck! |
| Thank you for the answer and site. I have already been to RotDoc but thought I would check with all of you too. Thanks again for the reply. |
| What is this under the floor? | wheresbob | Powerboats | 9 | 08-06-2006 10:26 PM |
| Redoing my floor | Steve71 | Fiberglass and Composite Boat Building | 2 | 04-30-2006 10:44 PM |
| Replaced Floor | leroy | Fiberglass and Composite Boat Building | 5 | 08-05-2004 09:41 AM |
| floor gone- now what? | Guest | Boatbuilding | 0 | 06-23-2003 05:37 PM |
| What to use for floor? | Materials | 4 | 08-06-2002 12:23 PM | |
