Old 06-13-2008, 12:14 AM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
I have no doubt you can make a very sea worthy boat using these panels. The look may not appeal to everyone, but for one off, build your own boat type projects, it may be very cost effective. I know the builder of these panels very well, they can make it any thickness and use almost any laminate schedule or resin you want, they also have many options for core material. Plywood is the low cost product and they have many types of foam, so the panles can be made very light and strong if you want.
I don't know if you've stopped by their plant, but they have many samples of panels for you to look at and they'll give you cost pretty quick.
Old 06-13-2008, 12:18 AM
EStaggs EStaggs is offline
Rep: 99 Posts: 100
The designer has, and he is specifying a somewhat specialized schedule for this idea, which they say they would do special runs for. He didn't get too detailed with me about it (im just the assistant, as we all know), but there were some specifics that I guess he had to sweet talk the plant into.
I am trying to talk him into getting the material made for a prototype, but as always money for R&D is the hardest to come by.
E
Come see the blog! http://www.stagboatworks.com
flexible fuel tanks for diesel Bentwood Boatbuilding 3 02-24-2008 11:49 PM
Flexible Moldmaking Sheet Material?? Capt. Chris Fiberglass and Composite Boat Building 6 08-23-2007 06:40 PM
Welded aluminum canoe design Jack D Davis Metal Boat Building 0 09-15-2005 06:20 PM
Welded Aluminum Shallow Water Boat dick stave Boat Design 15 03-25-2005 08:36 PM
Welded Aluminum Tunnel Jon Boat dick stave Open Discussion: All Things Boats & Boating 0 12-28-2004 11:35 PM
