Old 09-09-2006, 09:30 PM
Capt. Chris Capt. Chris is offline
Rep: 10 Posts: 67
Flexible Sheet Material for Building Molds/Plugs?
I am now in the process of building some small molds for my Topaz 28 project. The tackle centers, bench seats and some cabinets have many inside and outside corners, which I've found out to be the most difficult to fair out. So far we cut frames on my friend's CNC, in the shape of "U"s with inside corners being of a 2" radius, but just can't find a material that can make the bends and still be rigid enough to make a smooth surface. The idea was to lay up corners and then lay up some flat panels and piece them together. The parts won't be structural and we'll awlgrip everthing to finish. If any of you Pros know of a flexible skin that can be used in this application I would appreciate it. This trial and error stuff is getting old!
Thanks, Chris
Old 09-10-2006, 03:38 AM
wet feet wet feet is offline
Rep: 99 Posts: 258
I have dealt with this sort of situation by using 0.4mm birch ply and vacuum bagging strips aroung a cylinder.If the grain of the inner and outer layers is parallel to th e axis of the strip you can build up a laminate that is sufficiently rigid and smooth enough to take a quality finish.The essential thing is to use a large enough included angle to cover all the fillet situations encountered.
Alternatively,if there are long enough lengths with a constant angle,you can have strips of a suitable wood-basswood perhaps-machined to the shape you need.
Old 09-10-2006, 11:09 AM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
Some sort of tin should work. You could also slice PVC pipe of the right size, wax it up really well and use that. Sam
Old 09-11-2006, 01:00 PM
Toot Toot is offline
Rep: 17 Posts: 274
For 2D bends, in the roofing section of hardware stores you can buy sheet metal in rolls. That stuff can be bent pretty easily.
Also, the basswood idea is good. You'll have a little bit of core when you're finished which will be nice from a stiffness standpoint.
Urethane foam is also good and can be heated and bent to shape.
This next suggestion is probably heresy or something... But what about carboard? Like posterboards? Cheap cheap cheap. With the nice shiny side up and lots of wax, you can probably get it to separate from the part when you're finished. If not, you can sand it down and then add a few more layers on the back side to seal off any remaining paper fibers.
Are we off-topic yet?
Old 09-11-2006, 11:00 PM
Rep: 10 Posts: 67
Thanks for the replies!. Since my post I went back in the shop and tried a Celtex 2mm sheet, it made the bent great but ever place it came to a rib in the form it had a bump. Then I used a thin Formica, again bent good but still the same result at the ribs. I think the built up birch ply, or wood veneer is the ticket here and then thin Formica to top it. I'm hoping my tooling gelcoat will stick to this laminate. Never sprayed it on Formica before, then again if the finish is smooth enough I can just wax and pva the Formica. We plan on painting the parts to finish. Just a note... I used Duratec fairing primer in the mold instead of a gelcoat on some other flat panels that would end up painted. Pop them from the mold, then a light sand and it's ready for the primer or top coat. Worked great.
Thanks, Chris
Old 09-11-2006, 11:11 PM
Rep: 95 Posts: 462
what i often use for one off and custom moulds ( throw aways ) is cardboard and stick mylar on it no need to wax , sounds crazzy but works great. what u need is some stiff cardboard and or plywood a roll of cardboard the soft flexable type it comes in 100 yards rolls and a heat gun and tape, just with the plywood or stiff board cut the shape u want and then line it with the cardboard stick on the mylar tape the edges and ur ready to go. say if u wanted a tube plug just cut some plywood disks and wrap with cardboard, make sure u let the skin layer cure hard so the mould is some what sturdy
Old 09-11-2006, 11:12 PM
Rep: 95 Posts: 462
sorry i ment a glue gun not heat gun
Old 09-11-2006, 11:18 PM
Rep: 95 Posts: 462
also bristol board works great but give it a couple coats of wax before you put it together then just pva the sucker, always remember the kiss system when making plugs and moulds if u need some thing the size of a cornflake box us a cornflake box,
Old 09-12-2006, 08:21 PM
Rep: 10 Posts: 67
Thanks Jack!,
Just think, I've overlooked these perfectly good mold building materials all this time. I thought since it's for a "boat" it has to cost thousand of dollars for materials. Thanks for the reply,
Chris
Grancrete as a building material Packeteer Boatbuilding 17 09-27-2009 01:00 AM
Plugs/molds for plastic or polyethylene kayaks. William Le Croy Boat Molds 3 01-21-2006 03:22 PM
Getting plugs and molds made C-Salt Boat Molds 7 12-17-2005 03:15 PM
Canoe and Dingy molds & plugs for sale NYboater Boat Molds 1 07-26-2005 12:49 PM
Foam as main building material ? andrea Materials 12 02-17-2004 04:56 PM
