| flat panel foam sandwich stregenth hi, have a different post with no replies. maybee someone can help me with this (more general question) when using diab or corecell 5lb density foam as core material with std. poly resin / no vacumm bag / hand laid using say 1.5 oz mat 18 oz cloth 1.5 oz mat glass schedule. how important is the core in the whole stregenth equation ?? if a person took a 2ft X 4ft flat panel and buted to another 2x4 to make a 4x4 or 8x8 what ever the case might be. is the butted joint a serious weak point or does the glass provide the majoity of the stregenth ?? thanks for any insight you may have Mark |
| Hi Mark The core provides the offset between the two layers of reinforced fiberglass. The thicker the core the stranger the panel will become. It is important to understand that not all foam core is created equal and the mfgr's will be able to provide you with the details on that. http://www.diabgroup.com/americas/u_...concept_1.html http://www3.gurit.com/pdfs/corecell/...ine_Struct.pdf
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| Quote: http://www.diabgroup.com/europe/lite...andwich_hb.pdf
__________________ George: Architect (land lover type) Hovercraft & Vintage Porsche Owner http://www.boatdesign.net/forums/boa...ect-11973.html |
| thanks knotty, thanks for the reply and link do you know in my application with 3/4 in foam and the glassing schedule that i mentioned ( the cloth being 0-90 knited ) would this achive the type of stregenth required for decking and cabin top roof ( my concern is ) the but joints being the weak points. meaning would any load carying member need to be aligned with the but joints (as in the grid that would support deckin) my concern is that I will have some fairly large spans that would be unsupported due to fuel and engine room desgin thanks mark |
You should, with the advice of the foam manufacturer, be able to bond the individual panels of foam together without loss of integrity. The foam, from my limited understanding, does not provide any (well very minimal) structural strength to the panel. The strength comes from the fiberglass laminates on either side of of the panel. One side will be constantly in tension and the other in compression as you put a load on it. The opposing forces via the I-beam qualities of the panel is what provides the strength. The thicker the core the stronger the panel. You could do a test. You can also lay in some support battens to help bridge those large spans. ![]() You can also buy pre-formed composite parts that are ideal for reinforcing long span panels. http://boatbuildercentral.com/prodde...Preform_TR4007 ![]() I'm pretty sure your panel is going to be plenty strong. Just how strong I can't say. On a critical part such as a roof I'd use biaxial or triaxial fabrics, they are stronger. When I build mine I'll use foam for the roof but will rely on the designer to provide the scantlings for such. I'm assuming 1/2" corecell or divinycell with a 1708 top and 1208 bottom (possibly 9 or 10 oz 0-90 or 45/45) but that's just a guess right now. I definitely don't want any flex in the roof and I'm a svelt 240lbs plus the weight of a dingy & motor. Good luck!
| panels thanks, for the reply I was reading in the pdf's you linked and saw the "i" beam theory. also appreciate to pictures thanks, mark |
| First crack at resin infusion of a flat panel | KnottyBuoyz | Fiberglass and Composite Boat Building | 26 | 08-29-2007 11:44 AM |
| 25 yr old foam sandwich constructed sailboat | jksoft | Fiberglass and Composite Boat Building | 3 | 07-27-2007 09:30 PM |
| Sandwich hull panel to plywood bulkhead T joint??? | leegrace | Fiberglass and Composite Boat Building | 4 | 02-01-2006 09:42 PM |
| Composite foam board sandwich technique | scottperkinsusa | Boat Design | 11 | 09-18-2004 09:30 PM |
| Flat Panel Development | jprev | Boat Design | 7 | 09-19-2003 04:35 AM |
