Old 05-19-2006, 06:22 PM
bronconut bronconut is offline
Rep: 10 Posts: 4
Fixing my rotten floor on flats bay boat
I would appreciate your knowledge in helping me accomplish this job with satisfaction. First off, I have a 20 foot flats boat, a scooter (no sides). I removed the floor and am planning on replacing the stringers as well.
1. If I use 1/2" marine plywood do I need to seal the bottomside (underneath) with resin/epoxy?
2. If I used CDX and seal the underside as well, will it last 5-10 years?
3. Being that it is a flats/shallow water boat how many layers of fiberglass mat would be suffice. I was thinking 2 layers of 1.5 oz. for the floor..
4. What type of wood could I use for the 1x2" stringers. I was thinking pressure treated 1x4 pine, split down the middle....
5. Lastly, if I used polyester resin to coat the underneath of the floor what could I expect?
Thanks in Advance
Old 05-20-2006, 09:36 AM
jimslade jimslade is offline
Rep: 14 Posts: 304
If you search on this forum for stringer replacement you will find all you need to know.
Old 05-20-2006, 11:00 PM
Rep: 10 Posts: 4
Thanks for your input Jim. I have searched the forum, but couldn't find anything as listed below. Otherwise I would not have posted this question...Thanks again for your abundant knowledge.
1. Specific to a flats boat (in other words, less weight the better)
2. An answer on the amount of layers of fiberglass
Replacing Soft floor on Flats Boat bronconut Boatbuilding 3 05-22-2006 12:23 AM
18 and 20ft flats/bay boat molds for sale shallowwaterboa Boat Molds 4 03-05-2006 12:46 PM
air conditioned cockpit on flats or bay boat Tarpon1 Boat Design 13 12-01-2005 11:23 AM
Flats boat, bay boat air conditioned cockpit Tarpon1 Powerboats 1 09-16-2004 01:49 PM
Fixing a sub-standard commercial-built boat lockhughes Boat Design 3 07-10-2002 09:24 AM
