| Fish eye Hi all from Nor Cal, Had a quick question (if there is such a thing) regarding a fisheye problem we encountered in the shop yesterday. Just finished a small Transom repair on a customers Drag boat and wanted to give the floor a new shine as well (because things were going way to easy and our profits on the job were going to be way to high). Sanded out any imperfections and flowed out a thin coat of vinyl ester over the floor, looked good for about 5 min. and then (as we all were expecting) problems. Fisheye in no particular pattern or order. This morning the floor was resanded and ready to recoat, any thing we overlooked? Our air system is squeeky clean as is the shop / boat. use of wax and grease remover mabey. Any advice will be helpful as our profit margin is now a little more in check. Thanks, Dan |
| My guess, since it's a work boat you had oil or hydraulic fluid contamination. If I was going to do it I would clean it with mek or like then reclean with 2 rag meathod, then sand it, reclean it, then repair it. |
| old time formulators added detergent to reduce fisheye, modern additives are basically the same thing, an emulsifier , and soap is a great emulsifier. |
| Pescaloco is correct, sanding will not clean contaminates. MEK, alcohol, water- 3 or 4 times. Solvents are cheaper than paint.
__________________ Over the years I have spent nearly all of my money on boats, beer, and women. The rest of it I just wasted. |
| Go and find a flooring company that uses polyurethane on wood floor and ask for the dispersant liquid they use in poly !, it works a treat . Just a few drops and no more fish eyes !! dont know why its not in everything !! ![]() |
| classic symptom of surface contamination. Clean with MEK and tac rag and try again. De greasers on its own is no good. |
| Fish-like propulsion | Senyorita | Propulsion | 25 | 12-02-2009 09:03 AM |
| Electric fish | Frosty | OnBoard Electronics & Controls | 33 | 12-23-2007 06:21 PM |
| fish in my toilet pump? | Frosty | Open Discussion: All Things Boats & Boating | 7 | 04-27-2007 06:06 PM |
| Sun Fish | sunfish14slr | Sailboats | 2 | 09-30-2004 04:26 AM |
| Fish and/or Ski | robert606t | Powerboats | 0 | 03-16-2004 08:14 PM |
