Old 09-23-2009, 08:38 AM
Tarek Tarek is offline
Rep: 10 Posts: 8
Finish surface from infusing a multi-sided part around a core
Greetings everyone!
This is my first post so please be gentle.
I've been reading up on resin infusion, which seems to be pretty well documented here and everywhere else on the net, however I found very little on infusing 2 (or all) sides of a core simulateneously. I think it would be challenging to get a good finish surface, because that surface would have imprints from the flow media and bag, not the mold surface itself - unless someone here knows of a trick or two.
Thank you in advance!
Tarek
Old 09-23-2009, 01:09 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
Look up "lite RTM" google it.
Positives I've seen with lite RTM is you can pump out parts like mad. Both sides look wonderful, little or no print through.
Downside? You can't get near the strength to weight you can with open infusion.
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 09-23-2009, 01:40 PM
Rep: 10 Posts: 8
Thanks Jim,
I looked up lite RTM and it seems more suitable for thin walled double surface items, and require the construction of a second mold, similar to the case of a mechanical pressure mold. One would have to be very skilled at building the second mold, at a consistent and perfect gap from the first one. I would imagine would need calibrated wax and spend quite a bit of time perfecting the setup for the second mold. Is that what you are recommending?
I'm not sure if that is what I'm looking for, based on the items I'm looking to infuse - please enlighten me, if I'm missing something - I'm looking to infuse items like a surfboard or RC airplane wing in one shot, around a completely enclosed foam core and get the desired clean carbon fiber surface with no prints from flow media, peelply, bag fil, etc. and without resorting to building separate halves and gluing them together in a separate process. Are you saying it's the same process for those? how?
I aplogize in advance if my I sound misinformed
Thanks again. I greatly appreciate the help
TareK
Old 09-23-2009, 03:44 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
For RTM light, indeed calibrated wax is used to create a uniform laminate thickness. after that the mould edge details are added, and a thin laminate is created to act as the top mould. This is reinforced by adding more glass, some core, and a steel frame around the perimeter.
A bit labour intense, but targeted at higher output (up to 8 products per shift from a single mould) and larger series.
About your question: Yes, it is possible, but the core should act as a resin transfer medium. (have small cuts).
Soric (www.lantor.nl) is also a possibility. Wrap your core in Soric, then the fabrics, then infuse.
Old 09-23-2009, 03:51 PM
Rep: 10 Posts: 8
Thanks Herman,
So I guess if I use a foam core and score the surface with a knife in a grid pattern, lay the laminate and have only the bagging film as the top layer, it should - theoretically - work?
Regards,
Tarek
Old 09-23-2009, 03:55 PM
Rep: 10 Posts: 8
That made me realize there would be at least one (may be two) minor defect(s) in the part, at the resin inlet to be patched later? This also may be the case of the vacuum port?
Old 09-23-2009, 05:31 PM
Rep: 10 Posts: 8
I'm sorry if this was discussed before. Does anyone know where I can buy Soric in the US in small quantities?
thanks!
Tarek
Old 09-25-2009, 10:54 AM
Herman's Avatar
Resininfusion.info
Reply to your posts:
-yes, you are correct
-no, I have no idea. I am from the old world...
flow net/mesh for infusing Vanbokklen Materials 7 06-13-2011 02:02 PM
efficiency of surface drives and surface piercing propellers David Knight Powerboats 7 09-24-2009 05:10 PM
Low-sided drift boat >>>Steel Sheets Hacklebellyfin Boat Design 5 02-19-2009 06:31 PM
double sided sails dionysis Boat Design 13 05-24-2008 11:19 AM
Balsa core vs. foam core James Maldonado Fiberglass and Composite Boat Building 23 01-21-2006 11:12 PM
