| Fibreglass to Aluminium connection Hi everybody, In construction of a high speed Aluminium craft, for some reasons, we decided to design and constructed the superstructure by fibreglass. The problem for us is the method of connection between Fibreglass and Aluminium in the interface of superstructure and deck. Are there the rules and regulation for this type of design? It is pleasure to have your idea in this subject. I need the reference (book or paper) Thank you for your attention. regards Ahmad |
| make a flange , upstand aluminium say 75mm high make your fibre glass with small gap, then fit over and fill gap with sikaflex It is a nice way of building you can then machine screw in ss either tapping the flange, or bolting cheers Stu |
| Bingo, that's one way, it's not an especially difficult engineering issue. I suspect if you are having issues with this type of transition, then you should hire a professional to work out the scantlings. |
| Dear Whoosh and PAR, Thank you so much for your reply. Your comments were practical. We are in design step and we are going to try study different method in design office. We search the reference that help us to scantling this type of connection. Would you please tell me about the reference correspond to this subject? Regards Ahmad |
| Depending upon the environment, you should ensure that the difference in strain rates will not cause cracking in hot conditions. Hence you need to select the right type of glues and fillers. |
| Look an any composite boat building rules, most give detailed options for gunnel joints. The detail remains the same if one of the parts is aluminium. As mentioned by Ad Hoc, you need to use a fexible adhesive to allow for the different mechical and thermal properties of the parts.
__________________ Chris Tucker Marine Design Your Boat Your Way. www.ctmd.com.au |
you can always email myself through my website as a friend did several like this, after the first, it saved a lot of time as building nice houses in alum. is time consuming Chris I,m still trying find my rhino nested file, I have millions, it seems, like when we built with paper plans and one was redundant, we biffed it out, , but with pc, they seem to lurk somewhere on the hard drive defying efforts to find them, especially when they are not named ) |
| You also need to decide what type of joint it is. Is the joint "keeping the rain out" or is it "structural". This will also affect how you arrange the detailing. |
| How fast is your Internet connection? | Jeff | Open Discussion: All Things Boats & Boating | 53 | 08-07-2011 01:14 PM |
| engineering connection of transom to boat | wilfungus | Wooden Boat Building and Restoration | 4 | 02-27-2008 06:40 PM |
| propeller to shaft connection | Hisham | Boat Design | 3 | 02-16-2008 12:07 AM |
| keel-hull connection | Cvicek | Sailboats | 1 | 09-24-2007 04:15 PM |
| Radar wiring connection | huds_n | Electrical Systems | 3 | 07-09-2007 02:31 AM |
