Old 10-28-2004, 12:36 AM
Bqman Bqman is offline
Rep: 12 Posts: 26
Fiberglassing
Two questions, one, what exactly does salt water do to an engine and two I need to build a few parts on my boat and was wondering if I can get fiberglass sheets. And how do you do it.
Old 10-29-2004, 01:52 PM
fede fede is offline
Rep: 34 Posts: 281
Hi,I'm from Italy too,and often come close to Novi,I suggest you to take a look to www.nautikit.com
Old 11-01-2004, 02:57 PM
Rep: 66 Posts: 640
It tends to corrode the engine! Atleast the heat exchanger, hope you don't have water in your cilinders.
....and two I need to build a few parts on my boat and was wondering if I can get fiberglass sheets. And how do you do it.
Look on the internet for this subject, or ask your local supplier of glass, epoxy and polyester. Most of the time they give away these "how-to-..." booklets.
Dutch Peter
Old 11-02-2004, 03:59 AM
Rep: 2891 Posts: 8,798
If salt water is in places it's intended it slowly dissolves the surfaces. The water jackets on engines intended for raw water cooling, have enough meat in them to provide many years of service before they rust through. If the water is in places it isn't intended to be, like the crankcase and cylinders, you need to get the water out fast and "pickle" the engine until service can be done. If you try to start an engine with water in the cylinders, she'll hydro lock and you'll likely have to replace the engine, if not most of the internal parts will need replacement.
There are a number of places you can get GRP in sheet form, most ground to a specific thickness. This is a rather expensive way to build things in 'glass. The nature of typical 'glass work allows the user to create objects of near any shape, you start with goo and reinforcement and end up with a hard part.
There are many books on the subject of 'glass work available. Log on to www.westsystem.com and have a look at an industry leader in reinforced plastics. They have free booklets covering their products and techniques to use in your project. They are just an epoxy manufacture, but you'll learn much.
Stringer and Deck fiberglassing ? SpankyDxm Fiberglass and Composite Boat Building 7 08-15-2005 10:01 PM
Fiberglassing MDO drs3317 Fiberglass and Composite Boat Building 1 06-09-2005 02:43 PM
