Old 03-01-2005, 06:38 PM
bhd bhd is offline
Rep: 10 Posts: 17
Fiberglass with west epoxy over gelcoat?
The stringer I've dug out of my boat was encapsulated with a ton of fiberglass and gellcoat (bilg area). Can I laminate up another section of plywood outside of the current stringer, and encapsulate with epoxy/glass mat?
thanks,
david
BTW, this site has taught me more than anything else out there. I appreciate the feedback.
Old 03-04-2005, 02:48 PM
Rep: 66 Posts: 640
Yes, you can. Preferably with epoxy, it sticks better to polyester.
Dutch Peter
Old 03-04-2005, 07:13 PM
Rep: 1397 Posts: 7,216
If you use epoxy it is best to use cloth. The mat will use a lot of extra resin an make a weaker laminate. With mat you can do the repair with polyester. It is routinely done with good results.
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
Need to decide, epoxy, CPES, and/or Fiberglass? Guest Wooden Boat Building and Restoration 30 06-22-2005 12:01 AM
NGA Gelcoat over epoxy lamination ducaes Fiberglass and Composite Boat Building 2 03-11-2005 08:12 PM
Gelcoat over Epoxy wet-foot Boat Design 9 08-16-2004 07:58 PM
CPES, Epoxy and Fiberglass Questions Guest Boatbuilding 4 09-04-2003 09:06 AM
