Old 08-23-2009, 04:37 PM
roscoewalsh roscoewalsh is offline
Rep: 10 Posts: 9
fiberglass-v-gel coat
I am repairing a rudder(bent post) I know to remove all anti fouling paint before glass repairs, but does all barrier coating(interlux) and or all gel coat also have to be removed?
Old 08-23-2009, 05:35 PM
Rep: 2891 Posts: 8,798
If you are about to make 'glass repairs (damaged leading edge for example), the gel coat in the areas affected will have to be removed. Basically, you need to grind down to good, solid, non-delaminated or damaged mat/cloth, so the repair has something to really grip.
Gel coat nrodes Materials 13 01-25-2009 11:54 AM
gel coat alfiej44 Fiberglass and Composite Boat Building 10 09-05-2008 07:16 AM
gel coat instead of toolin gel ? meredog Fiberglass and Composite Boat Building 5 08-10-2006 09:53 PM
Gel coat jeremyb251 Materials 1 03-16-2006 01:40 AM
Gel Coat vs Fiberglass pramdx Fiberglass and Composite Boat Building 6 07-18-2005 07:44 PM
