Old 02-07-2011, 09:18 AM
mjkkemper mjkkemper is offline
Rep: 23 Posts: 16
Fiberglass Transome stairs for AFT cabin
I am building a set of stairs leading down to my swimplatform. (86 Carver Aft Cabin)Below is a picture of the plug. I have a quite a bit more work to do ( lip around the bottom edge, Flaring and rounding the corners) anyways this is my second build. The first was a swim platform. The platform was not as complicated in that it was a flat build.
I had a few questions and would most certainly welcome any advice.
My tentative layup schedule is as follows
Polyester gel cot
1 layer of veil – (polyester resin)
1 layer of 1.5 oz. copped mat
1 layer of 3 oz. copped mat
1 layer of bi-axle
1 final layer of 3 oz. mat
No coring material
A few questions
1. Will this be adequate for thickness and durability
2. Will the corners be hard to form the mat and especially the bi-axle around
3. Should I presoak the fiberglass on the sides so that the resin does not puddle at the bottom
4. Should I lay up in sections – sides then bottom. If so will this affect the strength of the stairs
I do not own a chopper gun but if I did (or had someone spay it) would it be better for this particular application? Also if you did use a chopper gun would you hand lay any additional layer or would just spaying a thickness of a ¼ or so be just as strong as a hand lay up
I would appreciate any feedback on the layup schedule and anything else
Thank You
Matt
Old 02-11-2011, 11:22 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Polyester gel cot
1 layer of bi-axle
No coring material
A few questions
Thank You
Matt
At a rough guess you almost need to double the layup you have written down !! The area where you step on the tread of the stair will flex so i would suggest you put a core on there , a minimum of 9 mm 5 ply with bevelled edges to Glass over . The rule of thimb with Glass parts you walk on is if it moves people will say its weak and you could gett cracking over time !.
Making beautiful boats is a passion never a chore !
Old 02-26-2011, 06:46 PM
Rep: 23 Posts: 16
here is a picture of the design
Fiberglass Transome stairs for AFT cabin-post-6086-1297888713_thumb.jpg  Fiberglass Transome stairs for AFT cabin-p2180351-640x480-2-.jpg
Old 05-15-2011, 06:44 PM
Rep: 23 Posts: 16
finished the last coat of fiberglass on the stairs and demolded
Hung it from the rafters and let gravity do the work
set the stairs up on the platform
Old 05-15-2011, 06:45 PM
Rep: 23 Posts: 16
pictures of access door to be installed
Planning on bolting it on this comming week end
Old 06-03-2011, 09:15 PM
Rep: 23 Posts: 16
all finished
Fiberglass cabin on a steel hull Tygafan Fiberglass and Composite Boat Building 5 11-11-2007 04:34 PM
Restoring 23' 1983 Wellcraft Aft Cabin I/O LMannyR Materials 2 07-20-2007 01:33 PM
Wine glass stern and small aft-cabin sailboat xarax Boat Design 2 07-12-2007 07:51 PM
Ergonomics - Stairs on Boats kach22i Boat Design 37 06-15-2006 05:56 AM
US made aft cabin deep V boats xarax Powerboats 3 11-27-2004 02:36 PM
