| Par, if one wanted to keep the transparency of a resin coating to let the grain of the wood show through, can epoxy be adequately treated to avoid UV damage? |
| Yes, epoxy coatings can be brightly finished with the usually suspects, shellac, varnish, polyurethane varnish or LPU clear coat. If the wood is 'glassed, then the fabric needs to be 4 ounce or less other wise the weave will show in some light conditions. This effect is more pronounced as the fabric weight increases. 6 ounce cloth is just barely visible for example. |
| Building a wooden deck on a steel hull | AWegener | Metal Boat Building | 8 | 07-04-2007 10:13 PM |
| Restoring a Fiberglass Deck | Joe Wood | Fiberglass and Composite Boat Building | 1 | 09-10-2006 01:04 PM |
| Wooden or Fiberglass | berkin | Boatbuilding | 10 | 12-31-2004 03:42 AM |
| Wooden/Fiberglass Scantlings | JEM | Boat Design | 16 | 05-19-2004 01:43 PM |
