Old 09-28-2008, 06:39 PM
macka macka is offline
fiberglass outboard powered
can anyone give advise as to wether this layup will provide enough strength on my 20 ft to support the power of a 225hp engine
original outer skin left intact
a layer of probond by fgi used to stick ply to skin
2 x 18mm struct marine ply bonded together with layer of 300gm cs mat
all clamped to outer skin till cured
all joins coved
4 x layers of 600gm cs matt
2 to 3 extra layers of 600gm cs matt at the edges for tabbing
and thats it
do i need to add more mat or will this be ok?
thanks
19ft P-Cat powered by 18hp Nissan outboard. Roy Achoy Multihulls 15 07-10-2008 09:53 PM
Fiberglass Cloth or Fiberglass Mat? Fiberglass Resin or Epoxy Resin? canoe42 Fiberglass and Composite Boat Building 4 06-30-2008 08:18 AM
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 03:54 AM
Outboard powered SOT kayak... retrosub Boat Design 14 04-09-2007 04:05 PM
mounting outboard to inboard/outboard pcromien Powerboats 25 03-03-2007 11:46 AM
