Old 12-07-2004, 04:39 AM
Saeed Saeed is offline
BoatBuilder
Rep: 10 Posts: 12
Fiberglass Oil Tank
Hi all,
Im tryig to make fiberglass oil tank, i just wanna make sure if i can use the GP resin or the iso marine resin .. any better idea !!
i have made one before and i used the iso resin and woven 800 one layer and 450 one layer its working .. but some friends said its wrong you have to use better resin than the iso resin
oh yes i also i need help with paint remover for the antifouling , the bottom paint.. here is the pic att .. it take time to remove the paint and its thicks paint killing my time to remove it
for the people how is looking for good mateilas and chaper prices such as
Gelcoat,Resins.Fibermat,actone,catalyst,mirror glaze wax, Durabuild 1000,2000,3000 and pigment etc
send me e-mail at ADMARINES@AOL.COM or give me your fax number and i'll send you the price list .. by the way im not materils suppler . i just want to help.
by the way im in united arab emirates
MISSION MARINE
Saeed
Old 12-07-2004, 06:11 AM
Rep: 700 Posts: 3,208
I have made many fuel tank for motorcycles from GRP.
The technique was to shape what ever very difficult shape was required from cheap blue foam.
Then paint the exterior of the plug with west 2 part epoxy (only recomended as it was avilable from other projects).
Pollyester resin disolves the foam ,so the epoxy is used as surface barrier layer.
When cured the plug would be covered in laid 3/4 oz mat (with cloth as reinforcement at mounting lugs etc) no roving is ever used.
When cured the gas fill is used to pour in old battery acid.
This completly disolves the internal foam plug.
AS a precaution an aircraft wing tank sealer (Aircraft Spruce source) is poured in to seal any pin holes.
Since this works for gasoline , it should work for oil too.
FAST FRED
Old 01-16-2005, 02:12 PM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 614 Posts: 720
Dear Saeed,
You may use a good grade of ISO resin for fuel oil.just make sure the inner layer contacting the fuel oil has at least a layer of resin rich veil cloth followed by two mat fiberglass. reserve the WR in the outer layer.If it is a large tank, abovegroung or underground, it must be stress analyzed to prevent leaking.
regards,
rxcomposite
Old 01-16-2005, 08:05 PM
Rep: 1397 Posts: 7,216
Why do you want to remove the old paint? If it is not flaking, just paint over it.
Old 01-16-2005, 08:51 PM
Kyle Kyle is offline
Registered
Rep: 10 Posts: 36
Gaonzo,
Say the bottom paint wasn't peeling but, you wanted a super smooth finish for show. Is one paint stripper better than another for removing 20 years of bottom paint on a fiberglass hull?
Thanks, Kyle
Old 01-16-2005, 08:53 PM
Registered
Rep: 10 Posts: 36
Sorry, I completely botched the spelling of Gonzo. Smashed my middle finger today.
Kyle
Old 01-17-2005, 02:39 AM
B. Hamm B. Hamm is offline
Registered
Rep: 16 Posts: 97
I've used Star-10 paint stripper on bottom paint for years, the only product I've found that will remove all the layers of paint at one time (no I don't sell the stuff<g>). The stuff just works. Have to do a web search for Star 10 products to find it though.
Bill H.
epoxy fuel tanks Boatbuilding 24 08-14-2008 04:36 AM
Water in Oil Problem ScCoghill Propulsion 3 06-05-2005 02:09 AM
Price of Crude oil Versus Resin RThompson Boat Design 4 06-03-2005 11:31 PM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 06:43 PM
Help with Replacing the Belly Tank in a 25' 72 Sea Ray Bugmanx Boat Design 9 07-24-2004 10:00 AM
