| You don't want to make a mold yet, I wouldn't think. If at all. Something like that, I would make a prototype and try it. Make "rough" modifications until it's right and then final finish it and use it as a plug and make a mold from it. For only one item, it is usually not worth it in time and material to make a mold. |
| thanks Sam ... a one off to mod sounds easier and less hassle for sure ... |
| Its really quite easy to make the internal shape on a board from thin fibreglass 1 layer of csm 450 glass . What is the outside diameter of your prop ?? Have you worked with pvc foams and are you good at making shapes ?? ![]()
10-12" OD .. haven't decided on motor spec yet, but I'm leaning towards the 12" prop no PVC foams experience, shapes = so-so in wood and metal |
| Theres a post about doing a mould for a similar shrouding for a hovercraft around. It was an easy thing to do with foam - for 12", you could make simple lathe from a drill and spin a piece of foam on it |
| rwatson, was the post about the hovercraft shroud on this forum? |
#25
Making Curves - is this one way? |
| 45ft Mold or plug wanted | izland | Boat Molds | 4 | 01-22-2011 02:50 PM |
| plug/mold surface finish for epoxy | srimes | Fiberglass and Composite Boat Building | 5 | 10-20-2010 11:14 AM |
| Building a plug & mold | Itchy | Fiberglass and Composite Boat Building | 17 | 03-08-2007 08:24 AM |
| Plug and mold construction | sandman1984 | Boatbuilding | 3 | 12-23-2005 07:08 PM |
| plug/mold fabrication | cfox | Boat Design | 8 | 06-23-2004 10:55 AM |
