| Fiberglass laminates and secondary bonding With the secondary bonding of epoxy, can you add additional fiberglass laminates to a lay-up that has cured, been flowcoated, and sanded, or is that just asking for delamination trouble in the future? |
| Secondary bonding on cured epoxy usually needs the removal of the amine blush and some grinding for bite. Usually I grind first then vac and wash with water not solvents. Water cuts the amine. Some resin formulas are suposedly amine free or small amounts and therefore can be relaminated without much prep. This would need to be discussed with resin manufacturer. I am always leary so I do the grinding.
__________________ Tom Aro |
| " been flowcoated, and sanded"...nup, not really, you are asking for trouble. We would not do this in the yard, so I guess that is all I can say.
| What is the job, inside a cupboard or structural? Is it epoxy flowcoat? |
| Boat Repair/Bonding Epoxy to Fiberglass- Question | thill | Fiberglass and Composite Boat Building | 3 | 02-28-2012 08:45 AM |
| bonding foam core to fiberglass | mungral | Fiberglass and Composite Boat Building | 5 | 09-18-2007 05:57 AM |
| Boat Repair/Bonding Epoxy to Fiberglass Question | thill | Materials | 6 | 03-12-2007 01:29 PM |
| Paper on Secondary Bonding | Toot | Fiberglass and Composite Boat Building | 3 | 09-15-2006 05:33 PM |
| Bonding Steel to fiberglass | jtm311 | Fiberglass and Composite Boat Building | 21 | 01-28-2006 06:49 AM |
