Old 10-18-2011, 08:27 AM
dimr's Avatar
dimr dimr is offline
Rep: 10 Posts: 7
Fiberglass Hull Help
I need a list of material densities and favourable thickness dimensions for 7.5 trailable motor boat.
Is there anyone can help ?
I am designing Trailable daily cruiser. i have finished the the hull. now i want to finish 3 d design .
I need to know density for hull and deck !
Thanks
Old 10-18-2011, 10:30 PM
Rep: 1493 Posts: 7,447
If you are designing the boat, you are the one to determine laminate schedule. Otherwise, you may have to hire someone to do the work for you based on a drawing.
Old 10-19-2011, 03:42 AM
dimr's Avatar
Rep: 10 Posts: 7
thanks Gonzo ,
i am designing the boat and i am learning about materials . Fiberglass is one of the material that i have to research . I was asking from which source i can find information about density and dimentions of fiberglass according to CE catogory-B ...
Old 10-21-2011, 01:58 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
This is an engineers job - there is no 'magic formulae'
It depends so much on the intended usage, weight, displacement and a dozen other things.
Insulating a fiberglass hull RyanN Fiberglass and Composite Boat Building 15 02-09-2009 06:09 PM
Restoring a fiberglass hull David55cobra Boat Design 5 12-09-2008 11:21 PM
Building a fiberglass hull? tom_fry24 Boat Design 3 09-20-2006 06:21 PM
Wood Fiberglass hull? ST1 Boat Design 1 06-17-2006 08:27 AM
Fiberglass boat from old hull... canadian_cowboy Fiberglass and Composite Boat Building 3 06-10-2004 04:14 PM
