| Fiberglass Flat Panels: Sources needed Hi; I need flat fiberglass panels: 1/8" to 3/8" thick and 4x8 or 4x12 long. Please send links or locations of any sources for these! BillB |
| Fiberglass Panels Quote:
Hey BillB, how are ya. I just happen to make fiberglass panels. I can make them any thickness you want, and you can have the option of a double-sided panel, which means that it is finished on both sides. White high-gloss gelcoat, or even a textured finish if you would prefer. So get back to me man, I'd be glad to help you out. Freebird. |
| flat fiberglass panels Hello; What is your company name, locations, web page, spec page, etc? Please send details ! I am in the Lower Florida Keys. BillB |
| Fiberglass Panels Hello again. This is great; I used to live in Boot Key Harbor, up the road from you a bit. I'm sure you know where it is. My location now is Victoria, B.C, Canada. I am the Head of a new division, Tirling Infusion Dept., with Tirling Industries, a well-established company for 25 years now. The different divisions are Refrigeration, Sheet Metal, Custom Plastics Creations, and now Infusion. We are working on a web-page, but don't have it up yet. It is expected to be ready within the next two months. I have created a way of making fiberglass panels that are finished on both sides. Of course I can also make them unfinished on one side, both sides, or whatever you need. Send me full specs, and I can send you a quote, and a time estimation of when I can get them to you. I wish I could deliver them myself- I miss it down there! Looking forward to hearing from you, Sincerely, Freebird. Last edited by Freebird : 07-19-2004 at 06:18 PM. Reason: Change of title |
| Have you got a web site up yet freebird ? |
| Fiberglass panel question I have a 1991 bayliner there are a couple of soft spots in the flooring I don't want to replace the flooring with wood and was wandering if I could do it with fiberglass panels or what ever? ANy ideas or can the wooden floor soft spots be fixed? Thanks let me know please. sulli1@hargray.com Quote:
| You could try cutting out the soft spots ether square or rectangle . Cut extruded aluminum 2" x 2" x 1/4" angle about 2 inches larger than the hole on 2 sides . and the other 2 cut to lenght after the first 2 are installed. . Drill and counter sink the deck about 1 inch from the edge of the hole with 1/4 inch drill, 3 holes per side . silicone glue and clamp the angle in place so that it sticks out about an inch inside the hole. Then drill the angle from the holes you already drilled . Use flat head screws and brass lock nuts to secure the angle and your patch with self drilling screws. I would use treated plywood for the hole patch if it is no larger than 1' x 1' It will last forever and carpet over . As for correct thickness ??? laminate the wood ??? If it is a larger section Then frame out the hole as before . Use the angle and use it also as a " joist" to span the hole ( no more that 1' on centers) You can laminate and build up the patch out of fiberglass mat to the correct thickness ( build a panel). if you didnt want to use treated ply . Caulk all the seems . Plan on carpeting the deck . Thats the only way to hide the patch . Hope this helps |
| How to Create 3D Hull from Flat Panels? | DougChapman | Software | 4 | 09-20-2005 01:03 PM |
| flat table3 panels | gasdok007 | Boat Design | 0 | 11-11-2004 09:02 PM |
| Stepped Hulls | Ryon Macey | Powerboats | 53 | 08-01-2004 10:44 AM |
| fiberglass panel boat building | rongo | Boatbuilding | 12 | 07-15-2004 01:49 PM |
| Unfolding formed boat panels to flat sheet | Rohan_Tink | Metal Boat Building | 3 | 02-23-2004 10:02 PM |
