Old 04-17-2007, 12:10 AM
wet-foot wet-foot is offline
Rep: 10 Posts: 175
fiberglass cloth thickness and strength
is there away to predetermine the amount of layers of glass cloth needed to achive a certain thickness? Also strength added per layer? Also what is the glass to resin ratio with regular lay-up compared to vacuum bagging?
Old 04-17-2007, 02:20 AM
Roly Roly is offline
Rep: 222 Posts: 471
David Gerrs "Elements of boat strength" does most of that bar the specific tensile/compressive value for laminates.But he does give a recommended laminate schedule for your size boat via a scantling number.And the build thickness of various fabrics.
Depends how diligent you are with each layer, I guess, & whether you use peelply.
I just did an epoxy layup of 810gm triaxial (4 layers) non-vacuumed and achieved 55/45% resin/glass ratio.Dunno how good that is? Perhaps somebody who knows can chime in..............
I do find that if I want a void free "peelplyed" stipple you sometimes have to add a little xtra resin on top and squeegee out. Just a tad.
Old 04-17-2007, 05:08 AM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
Common wisdom says that about a 10% improvement is obtained in glass/resin ratio when going from a careful hand layup, to a vacuum bagged peel ply, bleeder cloth method. Maybe 55% resin 45% cloth to 50/50.
Am I off the topic yet?
Old 04-17-2007, 09:33 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Vectorply http://vectorply.com/lamdesign/vectorlam_sw.htm publishes a free laminate design software that works as a plugin to Excel. It's a bit tricky to learn but can calculate most of what you're looking for, for an arbitrary laminate.
Old 04-17-2007, 10:32 AM
SamSam SamSam is offline
Rep: 464 Posts: 1,608
There is a chart here in the third reply. I would just post it but somethings not right with my computer. Sam
Fiberglass thickness
Old 04-17-2007, 02:46 PM
Rep: 10 Posts: 175
great chart
sam sam the chart really helped, thanks.
Copper Cloth CapKos Materials 2 07-16-2007 02:09 PM
Cloth over cloth, no mat Koz Materials 13 01-30-2006 06:18 PM
Fiberglass thickness rturbett Fiberglass and Composite Boat Building 3 09-09-2005 08:36 AM
Fiberglass thickness? welton Boatbuilding 2 07-22-2004 12:13 PM
Vectra cloth Ken Baker Materials 5 03-11-2004 07:38 AM
