Old 11-11-2007, 08:16 AM
Tygafan Tygafan is offline
Rep: 19 Posts: 11
Fiberglass cabin on a steel hull
I have a 44' steel hull and would like to remove the steel cabin by cutting it off just above the deck and replacing with a newly built fiberglass cabin. I am looking for suggestions on how to join the fiberglass to the steel. Bolting? Joining the fiberglass to the steel? ........
Also are there any issues with this? Is this a bad idea having fiberlglass mated to steel?
Old 11-11-2007, 08:20 AM
DanishBagger's Avatar
DanishBagger DanishBagger is offline
Never Again
Rep: 523 Posts: 1,543
It's considered spamming when you post the same question in three different forums simultanously.
Old 11-11-2007, 08:27 AM
Rep: 19 Posts: 11
Sorry if I have offended anyone. I figured that I would get better response by posting the question in all of the areas in which the question could apply.
Old 11-11-2007, 08:29 AM
Never Again
Imagine everyone doing that – wouldn't that be swell?
Old 11-11-2007, 08:33 AM
Never Again
Btw, I'm not a boat builder, so caveat emptor, but I'd bolt the thing onto a welded frame.
Old 11-11-2007, 04:34 PM
lazeyjack
make an upstand (flange) about 75mm high , make up your cabin, , get all ready, then put Sika 11fc around the joint and lower cabin over it
through bolt with c/s hex drive screws
Fiberglass over steel hull boat Guest Materials 8 12-12-2007 09:00 AM
Joining a fiberglass cabin to steel hull Tygafan Boat Design 5 11-15-2007 09:23 PM
Joining a fiberglass cabin to a steel hull Tygafan Metal Boat Building 1 11-12-2007 02:08 AM
Steel-made hull with fiberglass-made radius chine ? xarax Metal Boat Building 48 07-23-2007 11:35 AM
