Old 07-10-2008, 11:51 AM
martyweir martyweir is offline
Rep: 10 Posts: 2
Fiberglass boat Mods - carpet to fiberglas floor
Hi all, great website. Please forgive my ignorance - hoping to learn alot on here.
I have a '82 15' troller skiff and I have noticed over the past 2 seasons that the floor is getting soft in a few spots. I have lifted the carpet and the floor is approx 1/2" plywood covered with a layer of fiberglass "mat" I would assume (random fiber patterns as opposed to the grid like appearance of fabric)
I would like to replace the floor, however I want to remove the carpet and install a fiberglass floor. What is the best method to end up with a smooth fiberglass floor? Should I lay fabric / mat directly on plywood floor, resin, then gelcoat? No clue here. Is this too much for a newbie to tackle? Lots of sanding involved I'm sure. What about skid resistance for a wet floor? Anybody have any experience with this?
Thanks in advance!
Old 07-10-2008, 11:55 AM
Rep: 10 Posts: 2
Oh ya, forgot to add an important question...
The space between hull & false floor that I plan to replace - I've noticed the boat flexes a bit when I hit a wake hard (small boat, thin hull) I was wondering about stiffening the hull / added safety by installing a foam filler between hull/ floor.
Is there any product you'd recomend? preferably something like a sprayfoam type insulation? any input/links / suggestions are greatly appreciated!
Replacing floor in Fiberglass hull funkyblues76 Fiberglass and Composite Boat Building 2 03-15-2007 10:43 PM
Fiberglas cloth with or without mat, which to use sbklf Fiberglass and Composite Boat Building 1 10-12-2006 05:19 PM
soft spots in fiberglass floor LEASEGUY Fiberglass and Composite Boat Building 13 08-26-2006 10:08 PM
Advice on keeping my fiberglass hull true when re glassing stringers & floor back in. craigathome Fiberglass and Composite Boat Building 9 03-01-2006 10:46 AM
Cracked fiberglas sailortoo Materials 10 12-05-2005 11:49 PM
