| Fiber orientation on hull? I am laying up some 1708 biax on a sailboat hull. Long story but for a repair the hull will get 100% coverage of one layer. I want to buy all the hull stiffening I can out of the fabric & am guessing that 45 degree fiber orientation from sheer is about right. This sound correct? Thanks |
| If you want all the stiffness you can get from equal weight, then drop the 1708 and use 2 layers of 12 oz biax. Same total weight in glass, but its 100% directional glass. the mat does very little for stiffness and will only waste resin. I am assuming your using epoxy, otherwise mat may be necessary. This would also allow you to go one layer 0/90 then the other 45/45 - now you have bias and double-bias ![]()
__________________ www.boatbuildercentral.com |
| Vectorply offers some very nice quad ax materials. They aren't like the tri-ax of old that were like wetting out carpet, they wet out very well and they offer them in different weights in each of the sewn directions. |
| Carbon Fiber Hull over Shaped Urithane Foam | Pablo4077 | Materials | 14 | 02-13-2009 01:01 AM |
| Fiber orientation on hull? | bntii | Boat Design | 8 | 09-25-2006 06:47 PM |
| Fiber products | shaapoo | Marketplace | 1 | 03-27-2006 11:11 AM |
| Spreader Orientation | brawny84 | Boat Design | 7 | 03-29-2005 10:26 PM |
