Old 10-03-2011, 01:18 AM
bertho bertho is offline
bertho
Rep: 45 Posts: 143
fiber glass roll cutting
old question..
Any new system or trick to cut full roll of fiberglass ?
was using tape and wood saw before, was ok but not really clean cut...
have a 4 feet roll of biax 600grm to cut in 4 inch tape..
thanks
bertho
creating and building simple boat is much more difficult than complicated ones.....
Old 10-03-2011, 03:18 PM
Rep: 670 Posts: 2,457
The local guys wrap a poly sheet around a roll of biax cloth, then tape the poly sheet very tight onto the Biax roll, then cut off with a band saw. Seems to work well...If I see the guys this week I will ask what type of band saw blade and what band saw speed they find best for cutting.
Old 10-03-2011, 06:54 PM
Rep: 3125 Posts: 9,399
The right way is with a roll slitter, any other method will usually produce pretty rough results.
Old 10-04-2011, 08:18 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Think ahead !!!
easy to buy what you want when you want it !!
Band saw works !! sort of !! Take the blade out and turn it round slow but dosent jump and bite . wrap the roll really tight with shrink wrap and roll the roll across the table of the saw not push !!.
Mind you fingers they dont grow back if you cut them off !!!
How will you pick your nose again if they are missing ??
Making beautiful boats is a passion never a chore !
Old 10-04-2011, 08:27 PM
bertho
Rep: 45 Posts: 143
thanks guys,
so, nothing really new on this ...
next time will try to order pre-cuts tape rolls..!!.
cheer's
bertho
Old 02-15-2012, 09:37 PM
tom tomato tom tomato is offline
Easier Fiberglass Cloth Cutting
This won't work for cutting through an entire roll but I borrowed my wifes' FISCARS rotary cutter from her sewing box (it works just like a pizza cutter).
This gave perfect results and I was able to cut all the tape and shapes I needed with almost no fraying edges.
If the surface below the cloth has any irregularities the cutter will miss spots so use piece of smooth hardboard under the cloth and guide it with a metal straightedge on top. I even made some freehand cuts right on the hull. If I had to cut cloth on a regular basis this tool would stay in my toolbox.
The blades are replaceable too.
Old 02-16-2012, 01:08 AM
Speaking of cloth cutting, last week I needed to cut some lightweight glass fabric with a rotary cutter. Naturally you need a nice smooth surface to cut on so I zipped over to the shipyard garbage dumpster then dove in to search for a suitable clean piece of plywood. No luck , but as I was walking thru the yard I noticed an office being re decorated with a pile of good size pieces of wall board. I grabbed a slice as a cutting surface. GREAT..the cardboard surface is very smooth so it wont snag the glass fabric and has the perfect density to oppose the rotary cutter.
Old 02-16-2012, 01:44 AM
die_dunkelheit's Avatar
die_dunkelheit die_dunkelheit is offline
NA Student
Rep: 71 Posts: 72
I find the rotary pizza cutter type to work better than anything else, the glass doesn't move away from the cut as with any type of shearing cutter, edges are clean, and you can make very precise cuts. (I guess that was just my way of agreeing with the two before me..)
Naval Architecture Student
Old 02-20-2012, 02:09 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
I have one of these for roll cutting:
Works great...
Old 02-20-2012, 05:36 PM
Yep, those are called roll slitters.
PAR Plans
PARBlog
Fiber glass repair question pescaloco Boatbuilding 2 04-24-2011 10:27 AM
Cutting a roll to make tape KnottyBuoyz Fiberglass and Composite Boat Building 19 03-01-2010 05:06 PM
18 m fiber glass hull for sale (new) Nabil Marketplace 0 07-12-2008 04:08 AM
Weight of fiber glass jfblouin Fiberglass and Composite Boat Building 10 07-14-2005 10:30 AM
