Old 04-15-2010, 02:36 AM
amamini amamini is offline
Rep: 10 Posts: 19
Fiber configuration in lamination of hull thickness
Dear my friends,
I have some questions about fibreglass boat construction as follow:
2) Can we use 1 layer Mat + 30 layer (Woven roving) + 1 layer Mat + Polyester or Epoxy resin, to reache the required thickness, for example?
1) What is the best fber configuration in lamination of hull thickness (combination of Mat and Woven rowing fibre) to have best bending and impact strength?
Best Regards
Ahmad
Old 04-18-2010, 10:01 AM
lesburn1's Avatar
lesburn1 lesburn1 is offline
Rep: 59 Posts: 20
This will not be pretty.
I think you will need to give a lot more detail before anyone can help you.
Old 04-20-2010, 06:48 AM
Rep: 10 Posts: 19
Dear lesburn1,
Thank you for reply. For more detail, I can ask my question with more detail as follow. In my experience in fiberglass boat building, normaly in hand lay-up method, we use different types of fiber to obtain require thickness (and strength), for example using
1 layer gelcoat+1 layer Mat fiber+ 2 or 3 layers woven roving (or other type)+1 layer Mat+2 or 3 layers woven roving (or other type)+ . . . + Polyester or Epoxy resin= Requier thickness
My question is very clear.
- Can we use 1 layer Mat + 30 layer (Woven roving) + 1 layer Mat + Polyester or Epoxy resin, to obtain the required thickness?
I think that this detail will sufficient. I am looking forward for your reply.
Best Wish
Ahmad
Old 04-20-2010, 10:49 PM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 553
I've always separated layers of cloth or woven roving with a layer of mat. But I also used vinyl ester instead of polyester or epoxy, too.
Old 04-20-2010, 11:42 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
WR is normally separated by CSM to allow composite infill bonding between layers.
...and yes, try VE resin instead of cheap polys as stated above.
Fiberglass hull thickness AndamanSS Boat Design 4 12-24-2007 10:44 AM
Hull thickness for 16 foot skiff willfishforbeer Fiberglass and Composite Boat Building 10 03-18-2007 08:46 AM
WET vs DRY thickness and fiber/resin ratio jfblouin Materials 1 02-14-2005 01:32 PM
FRP hull thickness tdamico Boat Design 19 09-14-2004 08:20 AM
How to calculate the thickness of a hull? jb Boatbuilding 3 11-07-2003 09:12 PM
