Old 06-08-2009, 08:13 PM
Rich M Rich M is offline
Rep: 10 Posts: 23
FG and wood question
I haven't been around for a while - however, just built another small FG & plywood boat. This one is 10 ft long, 44 inches wide, and weighs about 80#.
I used 1/4 inch plywood and then 7-1/2 oz E cloth inside and out. The inside and outside seams were taped twice with 3 inch tape. Mid-grade polyester resin.
I had 2 questions - would I gain much strength by using 8 or 9 oz satin weave cloth over the 7-1/2 oz "regular weave" on the outside of the hull?
The second question pertains to applying the FG tape before or after the FG cloth - is it just as strong either way? Or is it better one way or the other?
Old 06-08-2009, 08:54 PM
rasorinc rasorinc is online now
Rep: 678 Posts: 1,127
Most builders use tape 1st then full glass over that after feathering. One layer of glass is for waterproofing only and scratch resistence. You get a little cohesion from it but not true strength. The wood provides the strength.
Old 06-11-2009, 01:09 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
What makes you think you need to re-inforce?
Old 06-14-2009, 10:49 AM
Rep: 10 Posts: 23
Its one of those "always try to do better" things.
I designed the boat over several years of building similar boats (8 ft boats) - always trying new twists and such. The boat worked out very well in its test run.
http://www.youtube.com/watch?v=blumcB0x2Is
I'd like to build another one that is about 10-15# lighter than this one by using lighter transom and bulkhead wood - and lighter flotation foam - and doing something else for a motor mount instead of 2 big pieces of 3/4 inch ply.
So, I'd just like to improve on the last one.
If I can gain any significant strength in slightly heavier FG, I would like to.
OR if I would be better off using S cloth and or epoxy resin.
I'm looking at my last boat build for a while due to finances and a possible move in the near future.
Question with composite wood determined_ange Wooden Boat Building and Restoration 12 06-04-2007 08:37 PM
How much wood (would a wood chuck ..)? Square feet/meter DanishBagger Materials 8 02-17-2006 09:32 PM
How do I keep the wood looking like wood? Laeelin Boatbuilding 9 06-12-2005 10:42 PM
Wood or metal, that is the question. MalawiMD Wooden Boat Building and Restoration 11 05-10-2005 03:50 AM
What wood? daniel k Wooden Boat Building and Restoration 5 07-27-2004 07:54 PM
