Old 09-19-2009, 08:16 PM
stu large stu large is offline
Rep: 10 Posts: 6
female mould vacuum bagging
Hi Guys,
I've been reading about the problems people have about vacuum bagging inside female moulds, when I had what might be a silly thought, female moulds are the opposite of male moulds, so why not use the opposite technique, instead of vacuuming a bag, why not try inflating one inside the mould.
Probably this has been tried before, if so can anybody comment on this.
Old 09-19-2009, 08:31 PM
apex1
Originally Posted by stu large View Post
Hi Guys,
Oh yes, anyone can.
Try blowing the same pressure into a closed bag than evacuating a few ccm gives!?!
Regards
Richard
Old 09-20-2009, 02:57 AM
Itchy&Scratchy's Avatar
Itchy&Scratchy Itchy&Scratchy is offline
Rep: 117 Posts: 141
Its called bladder moulding,thats how they make carbon fibre mountain and road bikes.
J
Old 09-20-2009, 07:24 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
The vacuum is in the item itself hence gets pressurised from both sides, while pressure is going to be on a large volume. Your stuff will have to be able to handle the pressure.
I actually had the same idea, pressure is much easier to make than proper vacuum, and you can get multiple times the pressure from pressure than from vacuum.
You get molds theat has a male and female and works in a press, you get a very dense, light and super strong item, but how to make it big enough for a boat ? It would be very very nice though.
If you can come up with something practical I would be interested for sure.
Regards
Fanie
Water ! Just gimme water !
Old 09-20-2009, 05:06 PM
wet feet wet feet is offline
Rep: 99 Posts: 258
Where might I find the source material relating to the problems of vacuum bagging in female moulds?
Old 09-20-2009, 07:58 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
Derek Kelsall uses pressure bags in his catamaran designs.
Thanks for the thred. I think I will consider this "positive" technique for some jobs on my next project.
Old 09-20-2009, 09:59 PM
wardd wardd is offline
Rep: 443 Posts: 925
i used to work for martin Mariette on lay up tooling made from aluminum and carbon fiber and sometimes the tape seal would fail, cleanliness of the surface that the tape adhered to was of utmost importance ( that can not be stressed too much ) any oil dirt would cause it to fail
our standard was not to lose more than a couple pounds over half an hour and that was after a vacuum was pulled and taken off, the bagging and tool had to hold it
like i said clean check and clean some more
acetone and denatured alcohol was used as it left no residue
and did i say make sure it was clean?
and we pulled vacuum from several places on the tool
the tools were put in an autoclave under heat and pressure
Old 09-21-2009, 04:42 PM
Rep: 99 Posts: 258
Thanks wardd,you have listed the reasons why bags fail to achieve the desired result regardless of whether the tool is male or female.The reminder to be scrupulous about cleanliness is apt.The fact remains that a vacuum bag, in an autoclave ideally,is normally a better idea than a pressure bag.Because no new loads are applied.
I had some experience with pressure bags in the seventies and they worked reasonably well for consolidation.The problem came in the form of distortion of the mould.We were using rigid supports,approximately an inch inside the laminate,and using the support to provide a reaction force to the pressure bag.The bag itself was a lot like a flexible water tank and was inflated using a small manual pump bought from a camping supplier and applying a pressure of about 4psi-as near as we could guess.If you do a rough calculation of the total force applied to a sixteen foot hull mould,it is no great surprise that the hulls were not quite the shape the designer intended.The situation gets worse if you have measurement rules to consider.I remain convinced that a vacuum system is a better idea and a much more flexible solution.
Making a female mould directly?? Raggi_Thor Fiberglass and Composite Boat Building 11 09-27-2009 10:10 AM
Foam core in a female mould Highwater Fiberglass and Composite Boat Building 1 06-14-2009 03:40 AM
What is vacuum bagging? RTaylor Boatbuilding 6 04-06-2008 02:14 PM
Recommended vacuum pumps for vacuum bagging? James Mills Materials 1 12-17-2006 04:11 AM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 04:25 PM
